First time jeep owner and new to the forums with some questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > First time jeep owner and new to the forums with some questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe ULTIMATE "Selectable" Locker System! BroughFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-28-2013, 05:18 AM   #1
Lucas04
Hi guys,
I've been looking around the forum for a few days and just picked up a TJ yesterday.
Now my question is, this jeep i bought has aftermarket wheels and tires so it does seem a bit higher than usual, but is there any easy way to tell if it's had any kind of suspension or body lift?
Thanks in advance!
Lucas04 is offline   Reply With Quote
Unread 03-28-2013, 06:43 AM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Take some pics and give tire size and we can tell you.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
TheBoogieman is offline   Reply With Quote
Unread 03-28-2013, 08:01 AM   #3
tyvanwie
tyvanwie's Avatar
This.
Also, is there a noticeable gap between the body and frame? Are there spacers on the springs? How big are the tires? You can also measure the springs, anything over 12" front and 8" rear is lift.
Sent from my iForum using JeepPhone
MY BUILD THREAD
MY FITNESS LOG/TRANSFORMATION
JK AND TJ PARTS FOR SALE
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is offline   Reply With Quote
Unread 03-29-2013, 11:52 AM   #4
Lucas04
Hey guys thanks for your replies. The tire size is 31x10.50R15 and I took some pictures but i'm thinking that based on the replies its at stock ride height.
Unread 03-29-2013, 12:01 PM   #5
TheBoogieman
Demonic Jeep Freak!
Looks stock to me.
Unread 03-29-2013, 12:05 PM   #6
Lucas04
Looks stock to me.
Ok, thank you!
Unread 03-29-2013, 01:23 PM   #7
Batty505a
TJs I've heard can go to 31"s without a lift kit.
If someone stuck a body lift on your TJ, you would see pucks/shims between the frame and tub
HTH
2006 Chevy Silverado (DD)
1998 Jeep TJ Wrangler Sport (DD)
1993 Jeep YJ Wrangler *Parts Vehicle*
Batty505a is offline   Reply With Quote
Unread 03-29-2013, 01:31 PM   #8
Necko2529
Surfing JF Since '04
Necko2529's Avatar
Looks really clean for a 13 yo vehicle.... and yes, its stock.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline   Reply With Quote
Unread 03-29-2013, 02:59 PM   #9
FarmerinVA
Just a flatlander
FarmerinVA's Avatar
Yep, stock suspension. Not stock wheels, though. Take a look the "sticky" posts at the top of the forum page, particularly "What does my TJ look like with ? lift" and "Stock TJ Specifications." Those will answer most of your initial questions.
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
http://www.jeepforum.com/forum/f9/ex...hafts-1234745/
FarmerinVA is offline   Reply With Quote
Unread 11-16-2013, 04:45 AM   #10
Batty505a
Sorry about the late reply. TJs I don't think come stock w/31" tires. My 98TJ sport has 28"
I'm saving up for 31s.
Unread 11-16-2013, 08:32 AM   #11
tyvanwie
tyvanwie's Avatar
They can fit 31s stock though.
MY BUILD THREAD
Unread 11-16-2013, 08:37 AM   #12
Ironhead
rubis came stock with 30.5, so pretty darn close
Ironhead is online now   Reply With Quote
Unread 11-16-2013, 10:44 AM   #13
WhiteMtnJeep
The Punk Made My Day.....
WhiteMtnJeep's Avatar
Unless it came with the tire upgrade many TJ's were 28 or 29 by 9.5 x15. My Sahara came with 30x9.5x15 with the Canyon Wheel package. I also though that some of the Rubi's came stock with 31x10.5x15's.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Polyphase Meterman IBEW Local 387
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
WhiteMtnJeep is offline   Reply With Quote
Unread 11-16-2013, 01:08 PM   #14
Necko2529
Necko2529's Avatar
All TJR came with 245/75R16 GY MTR mounted on 16x8 Moab alloy wheels.
Unread 11-18-2013, 01:46 PM   #15
King_Inky
I run 32"x11.5"s on my stock 98 TJ and have no rubbing problems whatsoever.
King_Inky is offline   Reply With Quote
