First Lift! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > First Lift!
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 02-28-2011, 04:28 PM   #1
Zjones1994
OneDayWheeler
First Lift!
Today i got my first lift kit. A rough country 2.5 inch suspension lift with springs and shocks. I plan on installing it next weekend and was wondering what this would include. I know i need to get a spring compressor and i have torx sets. Is there anything else?
Zjones1994 is online now   Reply With Quote
Unread 02-28-2011, 04:32 PM   #2
jmpowie
with a 98 about 5gal of penetrating oil start spraying it now!!!!!!!!! good luck with the shock bolts
jmpowie is offline   Reply With Quote
Unread 02-28-2011, 04:34 PM   #3
Zjones1994
OneDayWheeler
should that be it? i mean will i need longer brake lines or anything?
Unread 02-28-2011, 04:36 PM   #4
nikeo02
Nope. Factory lines will be fine. Depending on the kit, you should have everything you need.
But honestly, its true, start soaking bolts in PB. Shock bolts, links and so on...
2003 Yellow TJ
nikeo02 is offline   Reply With Quote
Unread 02-28-2011, 04:40 PM   #5
Zjones1994
OneDayWheeler
Alright. And do i just need to get my wheels aligned? it said have steering and drive shaft checked by professionals but would a self check after driving it a few times work?
Unread 02-28-2011, 04:47 PM   #6
jmpowie
get a alinment foresure if you want to keep your tires. a drive around the block will tell you if there is any problems with steering but with a 2.5 there should not be any problems
Unread 02-28-2011, 04:54 PM   #7
merkchop
merkchop's Avatar
At least it isn't on a YJ, those bolts are (or mine was) a pain to get out, ones on my 98 TJ wasn't so bad, didn't have to sawzall any of them.
Really isn't hard to do, just take your time and do it safely. Make sure you have it sitting on a good set of jack stands and do the front and rear seperatly, don't put the entire Jeep on stands (too much risk and no need to, unless you are having someone do one end while you do the other).
Follow the directions and it all should go fine and you should be able to complete it in an afternoon. Also it will be much easier with a spring compressor and make sure you have the springs seated in the brackets correctly.
Get it done and enjoy.
merkchop is offline   Reply With Quote
Unread 02-28-2011, 04:57 PM   #8
Zjones1994
OneDayWheeler
Alright and did you have any issues with it not being the full 2.5 inches? I just use it for a dd and its a 4.0l
1998 Chili Pepper Red Jeep
Check out my build!
http://www.jeepforum.com/forum/f22/t...build-1347318/
Unread 02-28-2011, 05:07 PM   #9
thirdeye
You could probably do it without spring compressors. But they will make it easier
Jeep or die!
Bay Area Norcal
[url]http://www.jeepforum.com/forum/groups/bay-area-norcal-region/[/url]
BUILD:
[url]http://www.jeepforum.com/forum/f22/history-thirdeye-1233347/[/url]
thirdeye is offline   Reply With Quote
Unread 02-28-2011, 05:39 PM   #10
dcope17
I needed new lines... mine would not reach at full droop and the wheels turned.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
.[URL="http://www.jeepforum.com/forum/f194/dcope17s-thoughts-bible-please-read-only-do-not-post-1333441/#post13115090"]My Bible Thread[/URL]
dcope17 is offline   Reply With Quote
Unread 02-28-2011, 05:46 PM   #11
wkrowe65
I just put the same lift om my 98 saturday. Well actually I just got the front completed. You absolutely should get strut compressors(borrow from autozone). Also, you will need paper towels for the blood, at least 8 beers and some sad sucker to help. These are mandatory! I went ahead and got a adj. frt track bar. Start early!
wkrowe65 is offline   Reply With Quote
Unread 02-28-2011, 05:54 PM   #12
Zjones1994
OneDayWheeler
Alright, and no beer for me XD i got into jeeps at a young age. 16 and first vehicle!
Check out my build!
Unread 02-28-2011, 05:58 PM   #13
wkrowe65
Sorry youre right, no beer. But seriously, it took about 5 hours to get everything rusty off. I had to cut the frt shocks off with a sawzall. You'll also need deep well metric sockets not regular ones and a ball-joint separator. Also a breaker bar and a big hammer.
Unread 02-28-2011, 06:00 PM   #14
Zjones1994
OneDayWheeler
Alright we have everything but the spring compress and ball joint separator. I know auto zone has the spring compress il check for the ball joint separator.
Check out my build!
Unread 02-28-2011, 06:14 PM   #15
cheapjeep06
I just installed my RC 2.5" last week. Did rear and steering stabilizer one day, did front end 2 days later. You will need a spring compressor. I had v-8 zj springs with 2 1/2" spacers in the front, and the rc springs were 1/2" longer yet, and I added a 1" spacer. In rear I had stock fronts; again, RC springs were longer. In front, with swaybar discoed, control arm hitting top of bracket, and jacking up opposite side, still needed compressor.
Soak all of the shock bolts with wd-40, pb blaster, something...I broke off 3 of the rear upper shock bolts when I put in new shocks 3 years ago...royal PITA!!! Used small cutting wheel on die grinder to cut 2 off, other one I was able to chisel off, and still had to drill holes so bolts would fit through. I even cut off part of the inner fender well to do this(no BL at the time).
Oh, and put the stickers on the shocks after you install them...wouldn't want to not be able to see them nice stickers.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline   Reply With Quote
