first ever jeep mods - JeepForum.com
post #1 of 13 Old 01-16-2006, 01:29 PM Thread Starter
onemoretry
Oldbie
onemoretry's Avatar
I have had a 2001 TJ for a couple of months and have gone a little nuts... I have ordered an OME 2.5", 1" BL, 1"MML, body armor front and back bumper (with tire carrier etc), hard top, disconnects, 1" spring mount extenders (or something like that), adjustable sway bars, and other stuff I am sure i forgot.
Is one weekend enough?
What order should I go with?
Thinking about getting rock monster internal bead locks. Any thoughts?
Should I go 32 or 33? I am thinking procomp muds.
Any idea where I can get more money or learn how to spend slower?
What do i tell the wife?
onemoretry is offline
post #2 of 13 Old 01-16-2006, 01:50 PM
CNY
Caught ridin' dirty
What kind of wheeling do you do?
CNY is offline
post #3 of 13 Old 01-16-2006, 01:52 PM Thread Starter
onemoretry
Oldbie
onemoretry's Avatar
as much as possible
I have always enjoyed playing in the mud and hope to continue. This will not be my DD, but I will not be able to trailer it. I live near the badlands in Indiana and hope to go there as much as possible to start.
post #4 of 13 Old 01-16-2006, 01:53 PM
TJgreg
TJgreg's Avatar
Just
Empty
Every
Pocket
tell the wife that "its a jeep thing" she wont understand. You're well on you way with all your new parts. One weekend will be enough, definitely if you have someone helping out and you know your way around your jeep. Just make sure you spary all the bolts / hardwar you will be messing with with PB blaster or wd-40 a day prior. Also, make sure yo have the right tools as well, such as a tie-rod puller (not reallly necessary), torque wrench, right sized sockets / extensions etc. If you have the coin, get beadlocks, but if youre not going super hradcore, I wouldnt worry about them. I'd go 33's.
Semper Fi
TJgreg is offline
post #5 of 13 Old 01-16-2006, 01:53 PM
DrD
DrD's Avatar
I'd go with BFG MTs but that's just my pinion...
RED JEEP CLUB MEMBER #344
2k2 TJ X
it's not your average grocery-getter...
3.07 GEAR CLUB MEMBER #14
polish jeep owner club member # 15
DrD is offline
post #6 of 13 Old 01-16-2006, 02:16 PM
Texas TJ
Texas TJ's Avatar
id go with the kuhmo MT's they flex real good and they are CHEAP and quiet
2001 TJ YELLOW
I flopped and broke my piece
If it won't budge, get a bigger hammer, if it breaks in the process it needed to be fixed anyway.
Texas TJ is offline
post #7 of 13 Old 01-16-2006, 03:29 PM Thread Starter
onemoretry
Oldbie
onemoretry's Avatar
rock monster
I haven't heard too much around here about the rock monsters. Does anyone have anygood feedback?
post #8 of 13 Old 01-16-2006, 03:40 PM
1BLKJP
Of course not knowing your exact mechanical ability or the tools that you have, but I would say yeah one solid weekend would be enough.
I would start with all of the mechanical items first, ie...lift, trac bars, disconnects, etc.... Then with the tires back on the ground it will give you more room to add your body lift and your new bumpers.
I don't personally know anyone that uses those internal beadlocks, but IMO judging by the type of wheeling your going to do you probably don't need them. I run my 35's at around 7-9 psi in the rocks and I have only rolled a bead once.
1BLKJP is offline
post #9 of 13 Old 01-16-2006, 03:58 PM Thread Starter
onemoretry
Oldbie
onemoretry's Avatar
mechanical ability
I am good with big hammers...
I have a brother in law that actually knows what he is doing. I am just dumb labor...
Thanks
post #10 of 13 Old 01-16-2006, 06:43 PM
97 TJ'd up
dont forget the BEER!
97 4.0 sport Flame red
2" OME lift w/ HD springs-tcase drop...Discos
32x11.50 MTRs on 15x7 offbrand aluminum
Body armor front dual tube, Rear w/ swingaway, sliders
MM 9.5 winch (ran out of $) KC's/ Hellas? Wet Okoles
Pioneer supertuner/ Alpines and CB
97 TJ'd up is offline
post #11 of 13 Old 01-16-2006, 06:53 PM Thread Starter
onemoretry
Oldbie
onemoretry's Avatar
beer
I am always good for the beer...
May wait till after for this job though.
I looked at the rock monster website on hutchison, and they have listed in one spot yj wheels, not tj, then in another spot they list tj not yj. Does anyone have these on a tj?
Sorry to keep bringing this up, but it is a lot of money, and I would prefer to have the DOT approved for all of the reasons listed elsewhere on this forum (I don't want to start another war on the subject, sorry)
thanks
post #12 of 13 Old 01-16-2006, 06:54 PM
JamboreeTJ
1946 CJ2A
BL/MML will take a good day. I just put a Prothane 1" BL and Currie 1" MML on my '01 TJ. I have a 4.0L w/ AC. That complicates the MML nicely because of all the crap hanging off the driver's side of the engine. If you have A/C, then you will have to remove the entire MM and the bracket that is bolted to the block as the compressor prohibits you from removing the through bolt.
There is a funny convention in cars and airplanes, etc. Bolts point down, or to the rear. I understand the down thing, but this job would be 90% easier if the driver's side through bolt was inserted pointing to the front. It would cut 45 minutes off the worktime. Of course, when I put the new mount back in, I put the through bolt back in pointing toward the rear.
Getting the MM plus bracket out between the UCA and front drive shaft is an exercise in geometry. Getting the larger MM plus bracket back up in there is equally frustrating.
I HIGHLY recommend a MML that has the inboard stud welded in place, rather than loose like the Currie Mount unless you have someone to help secure the bolt on the topside and hold a wrench on it while you go at the righty tighty thing.
Also, you will need at least 18" worth of extension and a universal joint for your breaker bar / 1/2" drive ratchet. Torquing the driver's side MML bolts will be a pain in the arse, especially the through bolt.
The long extensions will help get at the 2 body mounts that are back by the gas tank and upper shock mounts.
Other than the above, it is a pretty straightforward upgrade. 6 hours or so should do that part.
JamboreeTJ is offline
post #13 of 13 Old 01-16-2006, 07:54 PM
Dirty Backroads
Dirty Backroads's Avatar
If you were into rock crawling I'd say take the wife for a day of wheeling. When she hears all the sounds coming from underneath the Jeep she'll be convinced that you need skids and a lift.
Worked for me.
2005 Solar Yellow TJ Sport
Yellow Jeep Club Member #123
Originally Posted by Sniper111
Nothing like going topless with some Kid Rock blasting looking down on the rice boys with their dropped Civics wondering what Japanese steel would look like under the Mickey Thompsons.
Dirty Backroads is offline
Turner: A collection of Jeep, Jeep Mods, and Wheeling. Turner YJ Wrangler Technical Forum 39 05-17-2009 08:38 PM
Best mods you think you did to your jeep giggityjeeper YJ Wrangler Technical Forum 43 06-15-2007 09:12 PM
What Other Mods For my Jeep.... twinjeep97 TJ Wrangler Technical Forum 15 07-07-2006 11:25 PM
Mods. What have you done to your Jeep??? igofshn TJ Wrangler Technical Forum 30 07-01-2004 11:50 PM
My new jeep mods frhalevt TJ Wrangler Technical Forum 1 01-11-2004 01:18 PM
