Quantcast First diff fluid change at 12K miles - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > First diff fluid change at 12K miles
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 06-30-2008, 05:56 PM   #1
shadows_lair
Hi guys and gals,
I changed my diff fluid on the 06 Unlimited Rubicon this afternoon, and noticed some metallic buildup on the magnetic diff plugs, both front and rear. Not a lot, but definitely noticable. Nothing but a film, no filings or chuncks.
I believe this to be normal. Any comments?
Thanks,
Mike H. in Sedona, Az.
shadows_lair is offline   Reply With Quote
Old 06-30-2008, 06:05 PM   #2
john NC
as long as their weren't any big pieces or chunks i wouldn't worry about it
it's two metal gears turning against each other very fast, there's going to be some metallic buildup
john NC is offline   Reply With Quote
Old 06-30-2008, 06:19 PM   #3
jake1977
X2 no chunks, good to go!
jake1977 is offline   Reply With Quote
Old 06-30-2008, 07:02 PM   #4
TJamz
TJamz's Avatar
That's normal. It's when you have small chunks of metal then it's a problem. You'll notice the same when you change your tranny and t-case fluid as well.
TJamz is offline   Reply With Quote
Old 06-30-2008, 07:05 PM   #5
2jhanna
the other thing to look for, is in the bottom of your catch pan, if you see any metalic chips or glitter, as if you were panning gold.
jhanna
denton county, tx
2jhanna is offline   Reply With Quote
Old 06-30-2008, 07:06 PM   #6
FifteenCents
It's normal. When you start moving the gears don't have a lot of oil
on them. As the gear rotates around, the part of the gear in the sump
at the bottom of the pumpkin puts oil on the pinion gear.
Normal wear and tear.
The above post is my opinion and I have no facts to prove it... :)~
http://www.tjhardcore.com
The ultimate TJ owners only forum
FifteenCents is offline   Reply With Quote
Glock Forum
