Quantcast first cold weather with jeep - question? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > first cold weather with jeep - question?
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-08-2007, 04:48 AM   #1
IrishRED
4-Banger Forever!
IrishRED's Avatar
I know I am not supposed to use a scraper on soft top windows so what options do I have in the morning to get the ice off quickly?
IrishRED is offline   Reply With Quote
Old 11-08-2007, 05:42 AM   #2
Country Boy
Bovi-sapiens
Country Boy's Avatar
They make deicer in a can that is supposed to melt the ice. Not sure if it would damage the windows though.
2000 WJ Grand Cherokee Limited, 4.7l V8, Quadra-drive
Farming is easy when your plow is a pencil and you are a thousand miles from the cornfield. -Dwight D. Eisenhower
Don't curse the farmer with your mouth full.
Ah, cows. A thousand roast beef sandwiches wrapped in a gorgeous leather coat.
Country Boy is offline   Reply With Quote
Old 11-08-2007, 05:58 AM   #3
FuzzyDolly
Just brush off the snow lightly with a gloved hand. Then just run the heater and the ice will melt. Once you learn to drive with your mirrors, you won't even do this anymore. At this point, I don't even bother clearing my rear and side rear windows.
Joe
2005 Solar Yellow X
2" Skyjacker BB - 31X10.5\15 Cooper STT
www.wnyoffroad.org
FuzzyDolly is offline   Reply With Quote
Old 11-08-2007, 07:16 AM   #4
hollandbriscoe
Crank jeep turn heater on to blast furnace come back in ten minutes drive away no problems. You might put a pan of muffins in the front seat so you have something to eat on the way to work.
hollandbriscoe is offline   Reply With Quote
Old 11-08-2007, 07:32 AM   #5
Heyduke
When you stop and get coffee to go with your fresh, warm, muffins....be careful with your side windows when they are really cold, they can crack...
Heyduke is offline   Reply With Quote
Old 11-08-2007, 07:39 AM   #6
JeeperAbe
if im in a hurry i usually go out..brush of snow, turn on jeep, heat on full blast!, then i scrape front windows...then if the ice on the side windows isn't starting to melt, ill go and get a cloth with hot water and just wipe em down...usually does the trick by that time the heater has warmed the inside up and ur good to go. Other wise i just scrape the front window and drive, by the time i hit any main roads all the ice is gone.
1997 Jeep Wrangler SE 2.5l 4 cylinder auto, Stock.
Mods to come: 2" Coil lift, 31 MTs, Bumpers, Lights, Skids
JeeperAbe is offline   Reply With Quote
Old 11-08-2007, 07:40 AM   #7
erickpl
I find that if I can see through the upper portions of the windows, I'm good to go. Once I get moving, they clear off quickly.
But when starting, let engine warm a bit and crank the defrost. I minimize ANY handling of the windows when they are cold and the interior hasn't warmed up yet.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote
Old 11-08-2007, 07:44 AM   #8
omgsideburns
BAHAHAHAHAHAHA
but on a serious note..
its like 45 degrees here in florida. wtf?
omgsideburns is offline   Reply With Quote
Old 11-08-2007, 08:20 AM   #9
xltj
global cooling
Jeep: 1999 Black TJ Sahara, 6-cylinder, 4.0L, front dana 30, rear dana 44, 3.73 gears, 3" Teraflex, 15x8 Eagle Alloys, 33x12.50R15 Mickey Thompson MTZ, Bestop Sailcloth top, KC 150w Daylighters, KC 55w fogs, CB radio, 73k miles
Daily Driver: '05 Silver Civic EX Coupe, 4 cyl 5-speed Manual, ~35 MPG, 54k miles
xltj is offline   Reply With Quote
Old 11-08-2007, 08:29 AM   #10
pezley69
I just park in the garage! No frost or ice....
sorry...couldn't resist....
05 [B]Black[/B] TJ Rubicon 2" Spring lift, Hella 500's on the windshield, SRC front bumper, SRC rear bumper w/ tire carrier, SRC rocker guards/steps, Mile Marker PE8000 winch
pezley69 is offline   Reply With Quote
Old 11-08-2007, 09:27 AM   #11
01 Te-Ja
Heat wave.....I'd be on the beach baby!!!!
01 Te-Ja is offline   Reply With Quote
Old 11-08-2007, 09:46 AM   #12
squirrelmasta
It was 23 this morning in norther Wisconsin. No big deal. It doesn't really matter how cold it gets here it's never that bad unless the wind is blowing. Personally i would do the "let it run for a bit" gig.
squirrelmasta is offline   Reply With Quote
Old 11-08-2007, 09:59 AM   #13
nevadamike
I know I can't believe this, I left northern Nevada and moved back home to get away from the cold and this is what i get
nevadamike is offline   Reply With Quote
Old 11-08-2007, 11:38 AM   #14
SpoiledRotten
Roughin' it smoothly
SpoiledRotten's Avatar
Originally Posted by thesteve
global cooling
Good gosh. Don't let the tree huggers hear that. They won't know what to protest and whine about.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline   Reply With Quote
Old 11-08-2007, 12:09 PM   #15
4x4WranglerSE
just get a cup of warm water and pour it on your windows then wipe off ice and water. not really hot and not too cold cause it'll freeze again
2000 wrangler
stock...for now...
[URL="http://groups.myspace.com/DFdubJeepClub"]http://groups.myspace.com/DFdubJeepClub[/URL]
_________________________________
Low Output 4 Cylinder Jeep Club member #100
Jeep drivers who dig Country Music member #20
4x4WranglerSE is offline   Reply With Quote
Glock Forum
