Quantcast Finding TDC on '01 4.0 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Finding TDC on '01 4.0
Old 01-21-2009, 10:40 PM   #1
Baggot
I am performing the Camshaft position sensor alignment process the manual says to remove spark plug from #1 and feel for compression while turning the camshaft the direction it turns while running then after pressure is felt align to TDC on this guage on the engine.. the problem is i don have the guage that is pictured.
Am I missing something or is there another way. Thanks.
1 other thing: Looking from the front - the vibration dampener turns counterclockwise while running correct? correct me if im wrong.
Baggot is offline   Reply With Quote
Old 01-21-2009, 10:42 PM   #2
RnEmOvr
Never Forget
RnEmOvr's Avatar
get a friend and a flash light, thats how we did mine
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 01-21-2009, 10:48 PM   #3
Baggot
but what am I looking for? when the piston stops going up and starts going down?
Old 01-21-2009, 10:51 PM   #4
RnEmOvr
Never Forget
RnEmOvr's Avatar
ya you want #1 piston at very top, take the belt off (easier to turn), pull your plugs and jeep in N, i also suggest d/c battery just to be safe, but turn crank till piston is as high as it goes, make sure you rotate it few time as sometimes (depends on how the crank is set-up and i cant remember on jeeps) it will come up but its not the "full stroke" i dunno if thats true but i know i turned and my buddy said stop, and it ran great
www.cityprofile.com
Old 01-21-2009, 10:55 PM   #5
Baggot
Ha! thanks ill try it. Turn counter clockwise right?
Old 01-21-2009, 10:56 PM   #6
RnEmOvr
Never Forget
RnEmOvr's Avatar
i think so, it wont hurt if you go wront way since your going by hand
www.cityprofile.com
Old 01-21-2009, 10:57 PM   #7
Baggot
the manual said specifically not to do it opposite but didn't say which direction the belt goes.
Old 01-21-2009, 11:49 PM   #8
Baggot
Well I think I got it. Ill find out when I start it up.
Glock Forum
