Quantcast Finding the right TJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Finding the right TJ
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 02-15-2006, 07:37 AM   #1
Hada78CJ7
I'm currently shopping for a used TJ. I definitely want one with D44 and at least 3.73's. What is the easiest way to identify this combination while I'm crusing the used market? As you can imagine, when I ask a salesmen if a particular Jeep has such a set-up, they are clueless.
Hada78CJ7 is offline   Reply With Quote
Old 02-15-2006, 08:30 AM   #2
chilijeep
Start with at least looking for a Sport model. Sports, Saharas, and Rubicons come with or have the option of the Dana 44. It may be a option on the X package as well but I'm not sure.
1998 TJ Wrangler 4.0 5-Speed- Bushwacker 6" FLARES - Teraflex Flexarms - 5" Lift - RE1620 Rear Trackbar w/CV bracket - Teraflex BPE'S - 35" X 12.50" Goodyear MTR'S 15 X 10 Wheels - Rubicon Express CV Driveshaft - JKS QD'S Front Rock Bumper W/ D-Rings - Rear Swinging Tire Carrier - Hella 500'S - Rusty's Heavy Duty Tie Rod - Alloy USA 4.88's
chilijeep is offline   Reply With Quote
Old 02-15-2006, 10:34 AM   #3
FollowVirgil
Take a look, If the Axle is oval with a rubber plug it is a Dana 35. If it looks like a pear and has a steel drain plug it is a Dana 44. As far a gears, ask the salesman to contact Chrysler for a build sheet. You may also be able to determine if there is a LSD installed.
FollowVirgil is offline   Reply With Quote
Old 02-15-2006, 11:02 AM   #4
ColoradoTJ
Getting under the Jeep and taking a look is your best bet. Also, if it has a D44 then it will have 3.73 gears (unless its a Rubi).
Clint
Colorado Jeep Club Member #60
My Jeep
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline   Reply With Quote
Old 02-15-2006, 11:12 AM   #5
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by ColoradoTJ
...Also, if it has a D44 then it will have 3.73 gears (unless its a Rubi).
Not necessarily.
A D44 can be had with 3.07 gears too.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 02-15-2006, 11:14 AM   #6
william12345
Call Jeep customer service, 1-800-992-1997. I gave them 3+ vin numbers and asked them to tell me the axle/axle ratio on each. They had no problem doing that at all. They seemed glad to help. They did ask for the mileage of the jeep they were looking up.
william12345 is offline   Reply With Quote
Glock Forum
