Finding Gear Ratio - JeepForum.com
post #1 of 4 Old 07-09-2004, 11:20 AM Thread Starter
jeeperslax
Finding Gear Ratio
Just checkin to see if these numbers make sense on my front the ratio seems to say Dana 4.08 and the rear says something like dana 41 or 43 I couldnt really tell it... Tell me if these sound some what correct
jeeperslax is offline
post #2 of 4 Old 07-09-2004, 11:25 AM
chris06
chris06's Avatar
Check again. it should say 3.07 or 3.73 or 4.10 if you have a se.
They should be located on the left side of the differential. it the first 3 numbers.
2000 Black Sahara
Toys X Troy Croners
LED's
chris06 is offline
post #3 of 4 Old 07-09-2004, 11:43 AM Thread Starter
jeeperslax
yea it says 3.73 so what size lift and tires would that let me have... also how about the rear are those the same as the 3.73 or what... sorry for all the questions kinda new at this but definitely interested
post #4 of 4 Old 07-09-2004, 01:26 PM
xcanez
xcanez's Avatar
you have a manual/auto? yes the gears are the same front/back. Unless your like me, who has to save up to do the front. I have 3.07/4.56. For only a few more months.
-X-
YELLOW JEEP CLUB MEMBER #1
xcanez is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
need help finding ratio for my D35 parkerm26 YJ Wrangler Technical Forum 6 04-03-2010 02:45 AM
Finding Gear Ratio??? OutDoorDawg TJ Wrangler Technical Forum 5 12-21-2006 02:51 PM
Need help finding the right axle ratio! Fast29Car TJ Wrangler Technical Forum 3 12-17-2006 02:17 PM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
