Final Setup for the suspension?? - JeepForum.com
post #1 of 3 Old 02-29-2008, 12:40 PM Thread Starter
IH8ROADZ
Ok so heres what my final lift setup is going to look like. I have the 3" FT economy lift kit. A 3/4" spacer rear,a 2" (not sure if this is too much) for the front to compensate for the new coming arb bull bar and warn winch. And a JKS 1.25" BL & MML. All this to clear 35's. So can anyone share some pics of this setup and whether or not you think ill get ome good felx out of the 35's I mostly trail ride only once or twice a year so im not too worried about the d35. This summer im looking to go with a dynatrac dana 44 and super 30 kit up front with the regear. Please any input is welcome.
IH8ROADZ is offline
post #2 of 3 Old 02-29-2008, 12:50 PM
nicolas-eric
i have a 2.5" OME lift with 2" spacers on top and a 2" BL with 35s.
my lift is approximately as high as your lift.
to avoid tire rubbing i needed to install 2 bumpstop extensions.
here are some pics:
http://runicon.de/viewer.php?albid=5...e=3&imgid=4041
and some flex pics (still with the 2-3" OME shocks, longer 4-5" OME shocks are already ordered):
http://runicon.de/viewer.php?albid=542&stage=3
4" OME & 1" Spacer & LT Shocks 2" BL 1" MML JKS Discos JKS Rear Links OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 ARB Airlockers ARB Diff Covers 4.56 Gears SS Brake Lines
Warn Skids Genright Rock Slider Smittybilt Rock Crawler Rear Bumper Safari Snorkel OBA
12.000 lbs Winch Synthetic Winch Line 4x 130W Hellas 4x 200W Hellas @ Lightbar E-Fan
nicolas-eric is offline
post #3 of 3 Old 02-29-2008, 01:01 PM
Famous337
Famous337 is offline
opinions on my suspension setup yarmish TJ Wrangler Technical Forum 7 10-17-2009 09:38 AM
Opinions on Suspension Setup wrangler2007 TJ Wrangler Technical Forum 0 09-01-2009 10:34 PM
Suspension setup question? Mike318_ YJ Wrangler Technical Forum 4 02-20-2009 01:55 AM
did advice on suspension setup knotcher TJ Wrangler Technical Forum 3 03-05-2007 01:59 PM
Suspension setup questions atomicmoose YJ Wrangler Technical Forum 5 08-15-2006 07:24 PM
