#1 | |
Final Question/major Dilemma
Sorry for the repeat question. However I have searched and read other post.
The only 16x8 wheels I find(That I Like) have a 4.5BS(zero offset) http://eastcoasttires.com/wheelbrands/Gear-Alloy/Double-Pump-with-Black-Finish/ or are 16x9 with 4.5BS(-12 offset) http://www.wheelsforless.com/search_result.asp?Description=Black&Product_ID=mm9 5169 I will be running 285/75/16 bf goodrich m/t I do not have very knowledgable shops in my area so I need your help before I go and spend $1500 Question will they rub? Thank you for your answers. Steve
#2 |
pirate squirrel
if you run trails with your front swaybar disconnected, then yes, they most definitely will rub . . . but I can't say with certainty that they will rub just driving on the street . . . a little rubbing is not the end of the world, though
- Chuck - Nth Degree 4.5" short arm the "Dude" abides |
#3 |
They will most likely rub when you steering wheel is fully turned. Why not just get the wheels and tires you like and add a set of wheel spacers?
Black 2001 Wrangler SE, stats in profile |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
