filling A/C from empty - JeepForum.com
post #1 of 5 Old 08-04-2010, 04:46 PM Thread Starter
Dead_End
1990 XJ Cherokee
I need to recharge my A/C system after an O ring crapped out. How much r-134a do I need and is there anything special I need to do when filing it up?
[/Kevin]
_____________________________________________
Jurassic Park '90 XJ, '00 TJ
Dead_End is offline
post #2 of 5 Old 08-04-2010, 04:58 PM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
Several cans. But - you NEED to pull a vacuum on that system before you charge it. Leaving even that small amount of atmosphere air in there can creat too high of a head pressure and prematurely wear out the system. You will want gauges and add enough refridgerant to get about a 35 -38 degree coil (low pressure side, blue gauge).
Do it right - or you will do it over, and next time be replacing the compressor and maybe more....
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #3 of 5 Old 08-04-2010, 09:59 PM Thread Starter
Dead_End
1990 XJ Cherokee
Thanks. I kinda figured there would be something special I would have to do other that hook up a can. After a little more research I see what you're talking about.
[/Kevin]
Dead_End is offline
post #4 of 5 Old 08-04-2010, 10:14 PM
mikevsgeek
It's also recommended that the orifice tube and accumulator be replaced when the system has been opened to the atmosphere
mikevsgeek is offline
post #5 of 5 Old 08-04-2010, 10:52 PM
wushaw
Rockin jeep
wushaw's Avatar
24 oz of refrigeriant.
wushaw is offline
freon , filling , fill , ac , a/c , tj , wrangler
Gas keeps over filling traderdan JK Wrangler Technical Forum 5 01-02-2010 06:21 PM
Just empty every pocket? There already where empty nj95yj YJ Wrangler Technical Forum 7 07-16-2009 07:23 PM
Gas Filling Issue cmorra68 TJ Wrangler Technical Forum 17 04-17-2008 04:34 PM
Filling up LUNCHBOX_PGH YJ Wrangler Technical Forum 16 01-26-2007 12:27 PM
Gas Tank filling gwfoos YJ Wrangler Technical Forum 9 04-11-2006 01:57 PM
