Filling AX-5 through shift tower? - JeepForum.com
post #1 of 2 Old 02-21-2009, 10:07 AM Thread Starter
superslayer
I've heard it possible and easier to fill transmission fluid this way on an AX-5, anybody have a quick breakdown on whats involved as far as getting to it in this manner?
superslayer is offline
post #2 of 2 Old 02-21-2009, 10:09 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
you need a tube and funnel, remove shift cole covers, open the fill bolt on the side of trans (like you normally would) then put the hose in that hole (not the one the shifter uses) and put funnel in hose and fill till oil comes out
RnEmOvr is offline
AX15 shift tower bushing Opihi59 YJ Wrangler Technical Forum 27 01-15-2016 11:13 AM
AX15 shift tower bushing Opihi59 YJ Wrangler Technical Forum 20 08-17-2012 01:20 AM
Filling trans thru shifter tower...yes or no? mspell YJ Wrangler Technical Forum 3 09-05-2005 01:32 PM
Shift tower problem YJfrom94 YJ Wrangler Technical Forum 2 07-21-2005 12:43 PM
HELP!!! Shift Tower Trouble topfuel83 TJ Wrangler Technical Forum 2 05-07-2005 07:41 PM
