a few questions about Rubicon Springs -vs- TJ Springs - JeepForum.com
post #1 of 21 Old 08-10-2005, 11:52 PM Thread Starter
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
Is it true that if you were to put Rubicon Springs on a TJ Sport, that it would actually lift the TJ up another inch?
Do they fit without any issues?
Is it because the Rubi springs are more stiff?
How would the ride on the TJ Sport change, if at all?
Any input is appreciated!
Thanks
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig:
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline
post #2 of 21 Old 08-11-2005, 12:22 AM
abnormal
Platinum Member
abnormal's Avatar
From what I understand the rubi springs are taller by about an inch. Not sure if they are stiffer though. Go drive a rubi at a dealer and that should tell you if its stiffer or not. They do fit and I am thinking of getting some once its time for new bigger tires. My bfg a/t 31 10.50's are only 3K miles old!
abnormal is offline
post #3 of 21 Old 08-11-2005, 12:27 AM
river rat
Forum porn star...I guess
river rat's Avatar
I would not count on a full inch of lift. Some of the guys with a se say they are getting a full inch, but with your 4.0, I would guess maybe a half an inch if that.
Yes they will fit without any issues, but if you do get any lift out of them, I would realign your jeep because you will get a slight tow-out from the little bit of lift.
You will notice no change of handling after you realign.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #4 of 21 Old 08-11-2005, 06:19 AM
stedwest
I got an inch of lift with my SE. A friend got nothing (or close to it) using Rubi springs on his X. He did note that the ride was a bit rougher.
They are not taller springs, just a bit stiffer, and the lighter SE models get a little benefit out of it.
If you have access to a free set, however, they can be paired up to a BB. You'll experience less sagging over time. Otherwise, I wouldn't bother.
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
stedwest is offline
post #5 of 21 Old 08-11-2005, 06:37 AM
kaybone
I gained an additional 3/4" by adding the 106/130 rated rubicon springs to my REBB. Really your just getting less sag. My ride is firmer now but I like it becuase I get a little less sway when turning. I was glad I put them on because when I added my new heaver bumpers I really didn't lose any height, which was why I added them to my REBB in the first place, in anticipation of adding heaver stuff. My original springs where 104/128 and getting a little saggy. I got mine cheap on EBAY. I've read here on some thread that guys don't always like to wheel with the stiffer springs. Personally, I like them.
Gun Metal Blue Jeep Club Member #99
kaybone is offline
post #6 of 21 Old 08-11-2005, 07:26 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by stedwest
...They are not taller springs, just a bit stiffer, and the lighter SE models get a little benefit out of it.
Well said.
Wheelin98TJ is online now
post #7 of 21 Old 08-11-2005, 07:52 AM
03jeeper78
03jeeper78's Avatar
A Rubicon IS a TJ.
I think everyone else covered all the important info.
'03 Bright Silver Metallic TJ Sport
BSMCCEP Club Member #45
Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group
Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount
Next : Jeeperman rear bumper
'06 Candy Orange Honda Shadow Spirit 750
03jeeper78 is offline
post #8 of 21 Old 08-11-2005, 07:59 AM
RubiconSS
RubiconSS's Avatar
I removed my Rub springs and put on OME HD's and went up almost 3 inches. How I would go up almost 3" if I was already up 1", I don't know. That would mean that someone putting on the OME system on a Sport or an X would have gone up almost 4".
I think it would be worthdoing IF your stock springs were getting tired and you could get a set from someone who just removed their Rub springs like I did (w/ less than 5000 miles). Otherwise I'd probably spring for a set of OME's.
The OME HD's are stiff. Wish I had gone for Mediums. I have a heavy bumper.
'05 Rubicon (to go) '01 CamaroSS(to go fast)
RubiconSS is offline
post #9 of 21 Old 08-11-2005, 08:24 AM
NoUse328
If you want a little bit of lift for cheap...and we're talking really cheap since you can get the springs/shocks off of ebay (I've seen them for like $5 per set without shipping), I'd do it. The Rubicon ride is a lot different from the other TJ's I drove. Rides like hell on choppy turnning on-ramps here in Michigan, but the ride is better off-road.
NoUse328 is offline
post #10 of 21 Old 08-11-2005, 08:42 AM
ColoradoTJ
ColoradoTJ's Avatar
Rubicons have the same springs as most late model Sports and all Unlimiteds, if you have an 03+ Sport or Unlimited chances are you already have the same springs and would experince 0 lift. If you have an older TJ with some sag (like mine) they would be a cheap fix.
Clint
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline
post #11 of 21 Old 08-11-2005, 01:57 PM Thread Starter
Steelman
Steelman's Avatar
Thanks gang, for all of the replies. Sounds like I should only bother with a set if I can find them lying around locally.
As for this guy from WI...
Originally Posted by 03jeeper78
A Rubicon IS a TJ.
A bratwurst IS a hot dog! No difference, right?
-Bob
-(O|||||||O)-
my rig:
Steelman is offline
post #12 of 21 Old 08-11-2005, 03:21 PM
Jim Shanks
Jim Shanks's Avatar
But in all reality, he is right. A Rubicon is the most capable "stock" TJ ever made. But it is not the end all, be all machine. Mine ofcourse isn't in the category yet, but I know a few people that have regular old TJ's that would stomp on a Rubicon, even in fairly modded form. Now don't get me wrong, they are nice, but a quote comes to mind: Bad-*** Jeeps are built, not bought, the rubi just makes it an easier starting point.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #13 of 21 Old 08-11-2005, 04:20 PM
TJ on the Rocks
TJ on the Rocks's Avatar
"This Jeep is Not an SUV and Your SUV is Not a Jeep"
Right , and some tard said they saw me in my VAN the other day !
TJ on the Rocks is offline
post #14 of 21 Old 08-11-2005, 07:59 PM
ute
i put '05 rubi springs and shocks on my 97 se 4 cyl and got 1 inch
also did not notice a big diference in ride just a bit stiffer i say go for it if you get them cheap off flea bay
i paid $50 for shocks and stabalizer and $75 for the springs
ute is offline
post #15 of 21 Old 08-11-2005, 08:41 PM
Jim Shanks
Jim Shanks's Avatar
I feel your pain, now go and driver over their car!
Jim
Rubicon Springs vs Stock TJ springs dpgreen15 TJ Wrangler Technical Forum 13 03-05-2011 10:02 AM
Rubicon unlimited springs VS Rubicon 2 door springs sheriff1 JK Wrangler Technical Forum 1 11-27-2008 02:58 PM
Questions about installing Rubicon Springs and Dynomax Exhaust on my Unlimited 2004WRANGLER TJ Wrangler Technical Forum 27 10-31-2008 09:47 PM
How long a shock possible, I was told my springs are "rubicon springs" punk TJ Wrangler Technical Forum 5 07-24-2008 08:27 AM
Rubicon Springs? jim80proof TJ Wrangler Technical Forum 5 11-03-2006 04:36 PM
