a few questions - JeepForum.com
post #1 of 4 Old 01-06-2012, 06:28 PM Thread Starter
MMarty
a few questions
Hi all, been awhile. I just bought a 04 tj for a toy. I just ordered a 2.5 spring lift from jeepoutfitters and got a set of moab wheels. I don't know what size tire yet but am thinking 285s. At what point do I HAVE to have a slip yoke eliminator and adjustable track bar. Also do you think I can get away with the stock control arms and steering. This is my first tj so any input will be appreciated. Thanks.
MMarty is offline
post #2 of 4 Old 01-06-2012, 08:51 PM
durango-bob
2006 WK
You should be good with the stock driveshaft with that size lift. I have run TJ's with 4" of lift and was able to get rid of the vibs with a tcase drop of almost 2". The stock arms should also be OK with a 2.5" lift.
durango-bob is offline
post #3 of 4 Old 01-07-2012, 08:29 AM Thread Starter
MMarty
Thanks, believe it or not I am trying to keep this rig low budjet. I'm even going to repaint with dupli color paint shop system.
MMarty is offline
post #4 of 4 Old 01-07-2012, 08:57 AM
1999TJRED85000
x2 ... what he said.
I've got a 4" lift and I was able to get a smooth running Jeep by using a transfer case lowering bracket. It saved money for now. (Until I spring for the YSE and DS or wear out my CV joint, whichever comes first) With a 2.5" lift, you should be okay, especially with 285/70RXX tires. They're only 11 inches wide (same as mine) and if you choose a good tire, that will eliminate a lot of the vibrations too.
F U
1999TJRED85000 is offline
Lift Questions? Tire Questions john304 JK Wrangler Technical Forum 8 01-20-2011 07:31 PM
New Jeep Owner! Questions questions TP3P YJ Wrangler Technical Forum 7 11-01-2010 12:09 PM
SYE questions bigchevyman24 TJ Wrangler Technical Forum 6 06-04-2008 08:52 PM
I have a few questions jeeperkt TJ Wrangler Technical Forum 1 08-24-2007 11:23 AM
2 lug nut questions- Mickey Mouse kind of questions kaybone TJ Wrangler Technical Forum 2 05-04-2005 04:34 PM
