A few lingering front brake questions... - JeepForum.com
post #1 of 4 Old 05-25-2007, 10:17 AM Thread Starter
rastadog
rastadog's Avatar
2011 JK Wrangler
A couple of questions before I start my front brake replacement. Iíve read all the threads but didnít find the answers to...
I donít have any pulsing or pulling so Iím not going to have my rotors turnedÖhowever, do I still have to Ďde-glazeí them with sandpaper like the Haynes Manual suggests? And what grit sandpaper and how much sanding is necessary?...if at all?
The writeups include cleaning the caliper with brake cleaner. Do I also clean the rotors with braker cleaner?
Itís also a bad thing to get brake cleaner or anything on the pads right?
thanks as always,
jim
2001 Anniversary Edition Wrangler
2.5" OME HD Lift on ProComp M/T 32"s. Aussie Locker in front. Skid Row armor & fresh radiator fluid.
XM Satellite Radio - SKYFi2 and some cosmetic mods.
rastadog is offline
post #2 of 4 Old 05-25-2007, 10:48 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
thanks as always,
jim
Brake cleaner is bad. Do not use brake cleaner on brakes. Simple Green or any of the other detergent based degreasers are much better and actually clean.
A 60 grit non directional finish laid down with a random orbit sander is acceptable if you are energetic, otherwise, you can just do a pad bedding and break-in if the rotors are not grooved.
If you are not familiar with the sander, skip that step.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 4 Old 05-25-2007, 11:40 AM Thread Starter
rastadog
rastadog's Avatar
2011 JK Wrangler
...as far as sanders go all I have is this little thing:
What's the deal with brake cleaners being so bad?
rastadog is offline
post #4 of 4 Old 05-25-2007, 11:46 AM
DaOne
DaOne's Avatar
I'd just take some 100-120 grit sand paper and lightly sand the rotors in a circular motion. That should be all you need.
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline
Installed LockRight today, some lingering sideeffects... Roach YJ Wrangler Technical Forum 6 06-01-2008 12:16 PM
Brake Questions ST.GSXR TJ Wrangler Technical Forum 4 12-02-2007 07:28 AM
RE Rear Brake Line and E-Brake Cable Questions? Jeep4Rox TJ Wrangler Technical Forum 1 01-12-2006 03:42 PM
Brake Questions bberglund TJ Wrangler Technical Forum 8 09-26-2005 08:34 PM
Brake questions makizoo TJ Wrangler Technical Forum 5 01-19-2005 12:55 PM
