fender flare resto - JeepForum.com
post #1 of 4 Old 03-17-2010, 08:53 PM Thread Starter
DWEnvision
fender flare resto
Greetings. After considering buying new fender flares, I decided to restore them instead. Doing my research online, I found that there were many tricks and suggestions as to the best way to do it. So, I made up my own.
I first removed the flares so that to not mess with the paint. It is easy. just requires an 8mm socket and 8mm wrench. A little time consuming, but worth it.
Picked up a bag of 0000 steel wool, and a bottle of charcoal lighter fluid.
Put a little bit of lighter fluid on the steel wool and went to work. I didn't do a whole flare at once. Just a section at a time, wiping of excess as I went along. I found that as you go, you can see your progress. Once you see fresh plastic, i would stop and wipe. Once the whole flare was done, I would go back and even it all out. After that, I took a clean rag with some mineral spirits, wiped it down, then with a fresh rag, wiped off any excess. Then applied some armor all just for a temp. protective coating.
I am very satisfied with the result.the following is before and after shots.
Cheers..
http://img.photobucket.com/albums/v7...n/FILE0062.jpg
http://img.photobucket.com/albums/v7...n/FILE0063.jpg
http://img.photobucket.com/albums/v7...n/FILE0084.jpg
http://img.photobucket.com/albums/v7...n/FILE0081.jpg
DWEnvision is offline
post #2 of 4 Old 03-17-2010, 09:52 PM
1CleanTJ
1CleanTJ's Avatar
look good, should of painted them though or youll have to keep shining them up
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #3 of 4 Old 03-17-2010, 11:07 PM
HolidayJeep
Want pie now.
HolidayJeep's Avatar
Peanut butter! The full write up can be found here: http://www.jeepforum.com/forum/f7/pe...inside-384783/
Mike
Originally Posted by Slapahoe
Not to brag, I was the valid victorian my senior year. Best and the brightest of the bottom of the barrel.
Originally Posted by War Eagle
thunderspork
HolidayJeep is offline
post #4 of 4 Old 03-17-2010, 11:32 PM
StvDiego
Lighter fluid, hadn't heard that one before.. Looks like it worked, wonder how long it will last
StvDiego is offline
Fender Flare Help!!!! Irishfish23 TJ Wrangler Technical Forum 8 04-30-2009 02:53 PM
Fender Flare Extensions for keeping grim off rear fender flares? FrankGG TJ Wrangler Technical Forum 7 12-05-2007 09:29 AM
Fender flare ? rustzuk TJ Wrangler Technical Forum 3 04-08-2007 09:01 AM
fender flare dazed TJ Wrangler Technical Forum 3 02-13-2006 08:50 PM
