Fender flare bolts with spinning nut-serts...
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
I am trying to remove a few fender flare bolts but several of them (the rear mostly) just spin and have no access to grab hold of the nutsert on back. What else can I do to get these off? I'm becomming a spinning nut-sert myself!!! Lets try to keep it to actual tips, I'm not about to use a sawzall or anything like that.
2002 TJ Sahara, 4.0 I6, auto, d30/d35 with 3.73's, 33x12.5 bfg mt's, ome 2" lift and steering stabilizer, 1.25" JKS BL, JKS 1" MML, A to Z Fab ww2ww Rocker Guards, Teraflex adj front trac bar, AEM brute force intake, Magnaflow cat-back exhaust, optima yellow top, LoD front bumper with guard, LoD rear bumper with tire carrier, Delta Sky Bar, Delta Xenon Quad Bar H4 Headlamp conversion, Hi-lift... |
#2 |
i used an angle grinder to cut the head off and popped it out the back
#3 |
Have you removed the rear fender liner? You HAVE TO do that to access most of the rubber blocks that need to get removed.
For the ones that use nutserts try jamming a screw driver between the washer and the flare. Pry towards yourself while attempting to turn the bolt head.
Visit My Homepage! |
#4 |
I feel your pain on those nutserts! I have a 2000 TJ with the same issue. I think the only way to get them out is to cut the heads of the bolts of to remove the flares, and then deal with the spinning issue. I could get to some of them from the back to hold them still, but many of them are almost impossible to get a good grip on to loosen the bolt. Time for some grinding!
#5 | |
#6 |
Alright, option number two is to pry the crap out of that washer until you pop the nutsert out of the tub. You'll have to replace the nutsert with a rubber well-nut, like the one below. That's exactly what I did when I removed my stock flares and replaced them with Rubicon flares:
#7 |
nutserts are such a pain, I ended up cutting half of mine out with a hacksaw blade and then just using normal bolt and washers to put the other flares back on
Click here --> - Buy popular magazines at discounted price, help my daughter for school DIY jeep highline guide -> click here DIY highline guide Save up to 40% off at advance auto parts by buying online, pick up at store free! |
#8 |
I just took mine of and once I got one of the bottoms ones off I had someone try and pull on the flare while I tried to unscrew the bolts. It seemed to give the bolt just enough traction for it to come out of the nutsert. This work and they all went back on as well.
2004 Wrangler X Rubicon Express 4.5" Long Arm Tri Angulated Rear 35X14.5X15 Pitbull Rockers on 15X10 Simulock Ford 8.8 with 4.56 gears Dana 30 with ARB JKS quick Disconnect BDS rock slider AEM Brute Force cold air intake Metal Fussion Tube Fender Posion Spyder Crusher Corners |
#9 |
I just held the nutsert by my fingers, and used a box wrench to get the bolts out. i couldn't get vise grips to get a hold or anything like that.
once i figured put HOW to get everything out, it took 30 minutes to get them all, mostly because the fronts are hard to get to with big hands... :-) |
#10 | |
#11 | |
Only use 'em on the holes that you popped the nutserts out of. You may have to dremel or file the hole a tad wider for the nutserts to fit. Ya want 'em snug though.
#12 |
Well, I got off the bolts I need to remove, thankfully it wasn't all of them. Thanks for all the suggestions!
#13 |
i just used a wrench and locked it on the other side and unscrewed the bolts, very easy.
05 Grand Cherokee Limited, stock for now Son's 96 XJ 4 1/2 inch lift on 33's |
#14 |
Sorry I'm a little late. but Loctite will help.
I used my drimmel to take the head of the bolt off, removed the flare. The used a pair of pliers to pull on the bolt shaft to pull the nutsert out as much as I could. The squeezed the loctite into the gap. Gave the nutsert a turn to get the loctite all the way around and let it set up. Sprayed a little "3 in 1" on it, then removed the bolt shaft with the pliers The nutsert is still there and works fine.
The above post is my opinion and I have no facts to prove it... :)~ http://www.tjhardcore.com The ultimate TJ owners only forum |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
