FELPRO intake/ exhaust gasket - JeepForum.com
post #1 of 11 Old 03-10-2009, 05:45 PM Thread Starter
4.0l sahara
Has any body else had problems with the felpro intake/exhaust gasket not matching up well with the exhaust ports on there 4.0l? The one i bought matched all bolt holes and matched the intake ports perfect. Didn't matter which way it was flipped unlike a OEM gasket the sides aren't marked and they don't give you any directions. So i decided to try and trim it and after i put it together i have a small exhaust leak on one port and it's bothering me. I would like to fix it, I'm thinking of just getting a OEM gasket. Has anybody else had this problem? After a month of listing to it I'm ready to fix it.
Thanks
4.0l sahara is offline
post #2 of 11 Old 03-10-2009, 06:03 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
fill in your profile. what year 4.0L? exhaust ports were changed depending what year head you have.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 11 Old 03-10-2009, 06:08 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Fill out your profile first. Fel-Pro make good gaskets. I've used them, OEM, and Banks exhaust gaskets. Never had a problem with them leaking.It is a PITA! to seal an exhaust manifold gasket because of the small amount of room but it can be done.. an tightened so it doesn't leak.Your leaking is due to cracking at the collectors on headers in most situations, not the gasket at head if it was properly torqued.
GOLENJEEPTJ is offline
post #4 of 11 Old 03-10-2009, 06:17 PM Thread Starter
4.0l sahara
It is a 1999. The header is brand new thats not the problem. Yes it was tourqued right.
post #5 of 11 Old 03-10-2009, 06:19 PM Thread Starter
4.0l sahara
The retard at autozone must have given me the wrong one. Thats why I hate them.
post #6 of 11 Old 03-10-2009, 06:40 PM
GOLENJEEPTJ
Unless it has been marked for head side and manifold side, line that gasket up on all holes and ports just to save you the headache.Good luck!
post #7 of 11 Old 03-10-2009, 06:40 PM
GOLENJEEPTJ
post #8 of 11 Old 03-10-2009, 06:49 PM Thread Starter
4.0l sahara
well im going to go and get the right gasket at napa and pull it appart and try again with the right gasket.
post #9 of 11 Old 03-10-2009, 08:11 PM
topfuel83
I also have a 99, and ran into the same problem. Get a gasket for a 98 Wrangler and it will fit like it should. You should never have to trim a gasket like that.
'99 Jeep TJ Sport 4.0
Kilby Steering Skid, Skid Row Engine Skid
JKS Quicker Disconnects, 1" PA Body Lift, 2" BDS Spring Lift
33" BFG KM2's on AR Baja Wheels
><> Ryan
topfuel83 is offline
post #10 of 11 Old 03-11-2009, 07:40 PM Thread Starter
4.0l sahara
Ya but a 1998 has a different intake and my 1999 has the newer style intake. Well this is the gasket i bought at napa today part number# MS 93094 FELPRO. Can anybody verify this is the right gasket going by napa's website it is ,my vin number for the engine is S. The 1998 does have a different part number it's MS94790 . So if this doesn't line up maybe that's what i need. Does anybody know what head casting goes to what gasket?
Thanks.
post #11 of 11 Old 03-11-2009, 08:27 PM Thread Starter
4.0l sahara
well I think i found out my problem i'm glad i didnt open the one i just bought. 99's are suspossed to have the 0330 head casting but since mine is a early 99 I just looked and it has a 0630 casting so I need a 98 gasket. Felpro part #MS94790
Year............Casting No
1987-90......2686
1991-95......7120
1996-98......0630
1999-04......0331
2.5 4cyl - Is my Intake/Exhaust gasket bad? carcollector TJ Wrangler Technical Forum 0 01-06-2010 10:26 PM
intake/exhaust gasket question spoiler73 YJ Wrangler Technical Forum 5 04-23-2009 03:20 PM
Felpro or Hesco Oil Pan Gasket MEnginerd TJ Wrangler Technical Forum 3 04-05-2008 06:25 PM
i4 exhaust/intake gasket ... which way does it go ? intenseblu YJ Wrangler Technical Forum 3 10-25-2007 08:00 PM
Quick gasket ? (Intake/Exhaust) cheesycook TJ Wrangler Technical Forum 2 09-06-2005 10:11 AM
