Feel Kinda dumb asking this... Putting my TJ on a Lift (Work Shop Lift) - JeepForum.com
post #1 of 8 Old 03-31-2005, 05:53 PM Thread Starter
Ludoc
Ludoc's Avatar
I have access to a HUGE lift this weekend. Would you guys recommend putting the 4 lifting legs on the frame or the 4 bars that attatch to each axle? (Torsion Bars? Can't remember what they are called)
I had my TJ up on a lift a few days ago and the guy put the legs on the frame. My front and rear axles were sagging so bad I was affraid that they were going to fall out. I noticed as it was going up that the Torsion Bars (??) were sagging as the axle flexed. Thats why I was wondering if I should support them to keep anything from getting torn up.
RED 04' TJ - 2.4 4 In Lift, 31" Courser M/Ts, 4.56 gears, JKS Discos, Aussie Auto Locker
Just a basic Jeep... nothing special.
Ludoc is offline
post #2 of 8 Old 03-31-2005, 05:57 PM
JeepTJMan
Support the jeep on the frame if you have a big lift like that. Those armes i believe are your lower links, control arms. I believe they have a few different names.
JeepTJMan is offline
post #3 of 8 Old 03-31-2005, 05:57 PM
Dragonmaster
Dragonmaster's Avatar
Always lift from the frame with a hoist. Your axle will not "fall out" unless you plan on disconnecting your shocks and sway bars.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline
post #4 of 8 Old 03-31-2005, 06:19 PM Thread Starter
Ludoc
Ludoc's Avatar
So those lower control arms that are sagging won't harm anything? My shocks looked like they were completely out lol. Made me kinda nervous. No I don't plan on disconnecting anything. Did a full service on my Jeep the other day (Transfer, Both Diffs, and Oil) but didn't have the Allen Wrench to do the Transmission. Got the Allen wrench today and will be lifting it tommorrow so just wanted to be sure I wasn't hurting anything with those arms flexing like that.
Ludoc is offline
post #5 of 8 Old 03-31-2005, 06:26 PM
JeepTJMan
Well I believe there are some retainers located at the top and bottom of your springs to keep them from falling off when you flex. If you are missing those your springs might fall out with no weight placed on them to keep them compressed.
Not sure on this. Somebody please correct me if I am wrong. I dont want to give bad info.
post #6 of 8 Old 03-31-2005, 08:06 PM
Dragonmaster
There might be retainers, but 8/10 times there isn't, therefore your shock travel limits the axle droop usually, just be sure the springs are seated correctly before you fully lower the lift if they do happen to become unseated in the air
post #7 of 8 Old 03-31-2005, 08:27 PM
got4-Lo
support the frame
stretched *** tj
got4-Lo is offline
post #8 of 8 Old 03-31-2005, 10:03 PM
2k3r1
2k3r1's Avatar
Your control arms are SUPPOSED to flex like that. Lift it by the frame.
2000 TJ Sport, 4.0L, 5-spd, RE 3.5" with all 8 adj arms and adj trackbars with 35"s, D30 w/ Lockright, 8.8 rear axle, sye and CV driveshaft, M.O.R.E. 1" BL and MML, IPF headlights w/ H4 FATBOY bulbs, PSC power steering skid, rock-it man rockers, uniden pro 520xl WITH PA :)
Future mods: 4.88s and ARBs?, belly up, dif guards, Gastank Skid.
2k3r1 is offline
kinda dumb question but... Perturabo YJ Wrangler Technical Forum 6 03-21-2009 11:46 PM
Kinda newb lift question-lift springs signal34 TJ Wrangler Technical Forum 2 08-05-2008 07:56 PM
i feel dumb even asking but please help Columbia TJ TJ Wrangler Technical Forum 30 12-29-2006 09:19 AM
kinda feel like spendin a little $ phish832 TJ Wrangler Technical Forum 9 04-11-2006 10:12 AM
Best lift with stock ride and feel..looking for 2" or 3" lift no bigger thanks. Bobert360 TJ Wrangler Technical Forum 7 04-01-2003 10:34 AM
