Quantcast Favorite Mod Under $500? - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Favorite Mod Under $500?
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 12-22-2007, 06:48 AM   #31
ROG97
Flat skid $130 (actually 3/4"drop) Made a huge difference over the stock shovel.
but.... like most mod's theres other cost's to make things correct "Transfer case shifter bracket, 1" body lift, SYE, adjustable control arms, and new drive shaft for this one" so maybe a little more than $500 for this one
If you're not living on the edge you're taking up too much space
ROG97 is offline   Reply With Quote
Old 12-22-2007, 09:00 AM   #32
tamersinger
quicker disco's some rockers and skidplates.....and towstraps
2006 rubicon
tamersinger is offline   Reply With Quote
Old 12-22-2007, 09:56 AM   #33
Dogman
For me, I would say my engine skid provided a lot of piece of mind in the rocks.
Dogman is offline   Reply With Quote
Old 12-22-2007, 02:30 PM   #34
T18A
1977 CJ5
Originally Posted by NikVallens
Scratch and dent sale from 4 wheel parts. Technically used because they were on a show truck. Never actually driven on. Just rolled around. All 5 for 400
I got a Warn winch that way too for $400. No box, but everything there.
T18A is offline   Reply With Quote
Old 12-22-2007, 02:57 PM   #35
Lee Iaccoca
You can do probably do 80% of the trails in your state in a stock Wrangler (31s or less), if you just have a front Aussie and Sway Discos. That'll run you maybe $450 in parts if you do the work yourself. And you can do all that using good aired-down AT tires, not MTs.
You can probably do 90% of the trails in a stock Wrangler w/ATs in say, So.Cal., if you throw in a front and rear Aussie + sway discos and don't mind a lot of banging on the rocks. You'll probably blow an axle or do other damage to the drive-train or under-carriage at some point, which would bring a whole new set of costs. But even so, you'd gain a ridiculous amount of capability for what would probably amount to $700 bucks worth of the aforementioned parts.
Lee Iaccoca is offline   Reply With Quote
Old 12-22-2007, 05:04 PM   #36
jsealey
Heres one that allways gets people going, but I guaranty you will use it every time you drive your Jeep. A short throw shifter. It makes it more fun to drive adds a bit of bling and is less than $300. I just installed a Hurst on my NV3550 and think its great.
jsealey is offline   Reply With Quote
Old 12-22-2007, 09:53 PM   #37
buellwinkle
Terk XMDirect module, $69. Plugs in back of the radio and makes the Sirius ready factory HU play XM. Wife loves it.
Second best mod has been power door locks, under $100, cheaper that trading it in for a new Wrangler, haha.
Worst mod so far, Edge Trail Jammer, module connectors don't fit, TB makes noise, a lot of hassle for a "simple bolt on" and no weekend support. I think it qualifies, module and TB are under $500.
2005 Solar Yellow X
Automatic/Soft Top/OME Shocks/RE 2" BB/31"x10.5" Tires
buellwinkle is offline   Reply With Quote
Old 12-22-2007, 11:08 PM   #38
1966cj5
Originally Posted by Atmo_Mischief
Do you mind sharing how you got 50% off retail?
He's prob one of the few (or many?) that got them for $74 a piece when the Sam's Club in Columbia SC had a misprint on the website. ( Actually I dont think it was there fault but the corp minds who handle the website. ) I for one was one of the lucky even though it took a lot of phone calls to get it honored.
1966cj5 is offline   Reply With Quote
Old 12-23-2007, 12:16 AM   #39
ediot
A good mod I did was an I Pod wired hook up.Totally no performance gain but most of the trails have no reception and a CD would not last.
ediot is offline   Reply With Quote
Old 12-23-2007, 01:16 AM   #40
yellowismellow
rubber duck sicko!
yellowismellow's Avatar
may i ask how?????
yellow and black with those red net things...
got some old TJ and YJ stuff for sale, PM me...
yellowismellow is offline   Reply With Quote
Old 12-23-2007, 08:35 AM   #41
Wup This
5 17" Cragar Soft 8's from summit $57 x's 5 plus handling=$300
4 used TSL SSR's 37x12.50-17 =$350
PA 1 inch BL =$75
Catch All complete floor mat set= $193
I couldn't be happier with any one of these.
98 XJ, Pearl Green, 4.5" lift, 32's Daily Driven. BEAT IT! BREAK IT! FIX IT!
Wup This is offline   Reply With Quote
Old 12-23-2007, 09:17 AM   #42
paulthejeeper
I'm in the same situation too since lifting my TJ...
I've been looking at a few rear bumpers with 2" reciever and tire carrier...
I would much rather have my 33" spare outside than taking up what little room there is on the inside...
RRC has some for around $350-$475 depending where you look...
Also, A decent SYE and cv shaft seems to be around the $500 mark...
Yeah I take it offroad...my scratches have scratches!!!
[SIZE="2"][/SIZE]03 [COLOR="Silver"]BRIGHT SILVER METALLIC,[/COLOR]TJ,
4.0, auto,
4" rough country lift,
33" baja claws,
black 15" crawler rims,
more mods as budget allows...
[SIZE="5"]J[SIZE="2"]UST [SIZE="5"]E[SIZE="2"]MPTY [SIZE="5"]E[SIZE="2"]VERY [SIZE="5"]P[SIZE="2"]OCKET[/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE]
[U][COLOR="Blue"]USN JEEP CLUB MEMBER HULL#61[/COLOR][/U]
[COLOR="Silver"][U]BRIGHT SILVER METALLIC JEEP CLUB MEMBER #61[/U][/COLOR]
paulthejeeper is offline   Reply With Quote
Old 12-23-2007, 09:35 AM   #43
1fastR
Originally Posted by Jerry Bransford
$35 York F210 a/c compressor from a junkyard, 2.5 gallon air tank and mounting kit from www.onboardair.com/ Misc. parts like hose (high-temp only) & various air line fittings from your local hardware store. Works great, mine has been 100% problem free for the 7-8 years it has been installed.
Jerry, I haven't done any searching yet and yes I will try, but maybe you could do a write up on this and post some pictures. I am sure this is something lots of people would be interested in. Just a thought.
1fastR is offline   Reply With Quote
Old 12-23-2007, 09:41 AM   #44
jeepmuddin2005
Originally Posted by kittyhawk
If you are tall the Micsh Big Boy seat bracketts. They move the seats back 4"s.
Love them.
Where do you find these?
John Beaudean
www.semobs.com
jeepmuddin2005 is offline   Reply With Quote
Old 12-23-2007, 10:14 AM   #45
ROG97
OBA write up
www.jeeptech.com/body/york/
Glock Forum
