'fast back' CJ style C pillar cage, anyone done this? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 'fast back' CJ style C pillar cage, anyone done this?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 01-09-2015, 06:06 PM   #1
danielbuck
I'm about ready to start working on the cage of my TJ, finally, haha! I've had tube sitting around for a while!
I'm leaving the B pillar factory, and it doesn't look like it'll be to difficult to tie it to the frame. For the A pillar I'm using the poly/synergy pre-bent tube, through the dash down to the floor and tied in to the cage.
For the C pillar, I'm going to cut off the factory C pillar completely, and use straight tube similar to CJs, "fast back" style I guess. And also run a tube horizontally from the b pillar to the c pillar just below the top edge of the tub.
Looking at where the C pillar meets the body, I don't see any real good way to tie that in to the frame. On the driver side there's the filler neck and hoses, and on the passenger side there's the charcoal canister. So I'm thinking about using a large plate on top of the wheel well, and just spreading the load to the body and rear corner guards.
The seats will be a bit lower, and a bit more forward, and mounted to the cage.
Anyway, anyone done a 'fastback' style cage? Any photos of how (if at all?) you tied the C pillars into the frame? Or any other photos/suggestions.
Here's how it is now, and here's a photochop of what I'm going to do behind the B pillar. I'll have some additional triangulation/gussets there, but these will be the main tubes:
Daniel Buck - [URL="http://www.danielbuck.net"]www.DanielBuck.net[/URL] - [URL="http://www.dnsfail.com"]www.DNSFAIL.com[/URL]
danielbuck is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 07:00 PM   #2
billiebob
Very RETRO !!
What about twinning the main b pillar so you don't need to move the seats.
Maybe use a bigger tube on the fastback. Matching the rest.
Can't you anchor to the original c pillar anchor?
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 08:04 PM   #3
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
http://www.pirate4x4.com/forum/jeep-...on-thread.html
some real good info here.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 08:46 PM   #4
jarrodblake
1997 LJ Wrangler
I did it to my old LJ last spring, miss that jeep. While your at it I would replace the stock front Header Bars, as they will fold up it you ever roll it.
jarrodblake is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 11:29 PM   #5
danielbuck
I don't know if I'd want to double up on the B pillar. As for moving the seats, that's more of a seating preference than anything. Right now they are probably 2 inches to high (using the factory seat brackets) and maybe a little to far away. If it looks like headroom is an issue with straight bars for C pillar, then I will put a bend in them right before they hit the B pillar to give more protection.
As for mounting the C pillar, from the factory it's just a small plate on the tub. I was thinking maybe a larger plate to spread the load a bit more, if there's no good/easy way to tie it to the frame.
Yep, the B pillar hoop is the only factory item that's going to stay there. Everything else will be 1 3/4" 120 wall and braced at all major intersections. My photochops are only showing the C pillar here, since that's the part I'm a little unsure of.
What did you do to mount the C pillar, just mount it to the body with a plate like factory?
Originally Posted by RnEmOvr View Post
yea I've been going through that thread off and on, good stuff
Unread 01-10-2015, 04:43 AM   #6
TimV
I had mine built with a fast back style. None of the factory cage is left though. The B pillar is in the same spot however, because the factory soft top fits perfectly. No issues with headroom for me.
It's not an addiction. It's a way of life.
TimV is online now   Reply With Quote Quick reply to this message
Unread 01-10-2015, 09:51 AM   #7
danielbuck
what did you do with the C pillar mount, just a plate on the tub?
That's a stout looking cage, good triangulation!
Unread 01-10-2015, 10:13 AM   #8
TimV
C pillar is just a plate. A and B are tied into the frame. The A pillar is actually tied into the rocker guards first, then down to the frame. I'm extremely happy with how it turned out. I hope to never need it, but I feel like I can trust it is I ever do need it.
Lots of triangulation was definitely the goal. As you can probably guess, I have no plans to ever run a back seat. That made the fast back style an easy choice.
I had it built by Zach at A to Z Fabrication. They did a great job getting it done. I thought the price was very reasonable too, considering how many welds, bends, and tube are in it.
Unread 01-10-2015, 10:17 AM   #9
danielbuck
Yep, no more rear seat for me, my rear seat and seat belts are already spoken for, so that deed is done. haha
Yours looks very similar to what I'm planning on doing with mine. Like yours, I'm planning on an X on the B pillar, and a V from the B to the A. I'd love to see more photos if you have them. Feel free the PM them to me or post them here if you don't mind
Yours looks alot more stout than most cages, I wouldn't worry about it's strength! I wonder why more cages don't have much triangulation.
Unread 01-10-2015, 10:42 AM   #10
joe_jeep
Im doing something similar to my lj.
Using a bikini wrap around windjammer combo.
Kinda 70s pick up look.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 11:13 AM   #11
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
The old "wrap around."
Sounds nice.
Mail crawling.
MisfitSeven is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 01:59 PM   #12
hulud44
Fish Monger
hulud44's Avatar
im about to do this in a few days. Had some tube bent up for the rear. Was in the process of cutting off the rear C pillar when my grinder blew up on me. Been sitting with half a cage C pillar for a few days now hhahahaa
2000 Wrangler/ Waggy44/ 8.8/ 4:88/ Locked/ 38 TSL SX/ 3-4 link/ 103" WB/ Atlas 4 10.3
NYCJC
http://www.jeepforum.com/forum/f22/p...build-2789314/
hulud44 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 02:09 PM   #13
danielbuck
Right on
Those of you keeping the factory B pillar, are you welding up any bolt holes or other holes in the B pillar that aren't being used? There's alot of holes in mine, LOL Thinking about welding them up.
Unread 01-10-2015, 02:14 PM   #14
hulud44
Fish Monger
hulud44's Avatar
I have the AtoZ sport cage up front. I welded that to the stock B. I also plan on welding the sectional pieces on top the stock B as well.
NYCJC
Unread 01-10-2015, 02:15 PM   #15
MisfitSeven
MAiL Crawler.
Originally Posted by danielbuck
Right on Those of you keeping the factory B pillar, are you welding up any bolt holes or other holes in the B pillar that aren't being used? There's alot of holes in mine, LOL Thinking about welding them up.
I welded all mine up. Plus I welded the B pillar...it is three separate pieces.
Mail crawling.
