FAQ - How do I turn off the dome lights with the doors removed?
#1 | |
JEEP FREAK
You have 3 options to disable the interior dome lights when the doors are removed:
1. Remove fuse #4 labeled "door sw defeat" found in the fuse box located behind the glove box. It is the far lower, right fuse. Be advised this will also turns off your "Headlight On" reminder chime, but you can still turn on the dome light with the dimmer control as before. 2. Install/wire-in a switch. This can be purchased as a kit through several Jeep parts vendors or you can piece together your own kit very easily. Here's a thread with a nice write-up including pictures: Interior Light By-Pass Switch Write-Up3. Install clips that attach to the door pins (see pic below). These are also available from several Jeep parts vendors for around $10/pair.
98 TJ Last edited by Wheelin98TJ; 08-03-2007 at 09:57 PM.. Reason: Added link |
#2 |
Do it right or not at all
![]() Join Date: Jan 2003
I was waiting for Wheelin98TJ to make this a sticky but maybe he forgot so it is now. Hopefully it'll get switched over to the FAQ before long but I'm sure he has plans for it already figured out.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#3 |
JEEP FREAK
Thanks Jerry.
There is now a link to this thread in the FAQ.
98 TJ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
