Quantcast FAQ - How do I determine my gear ratio? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > FAQ - How do I determine my gear ratio?
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Closed Thread
Old 10-06-2008, 07:21 PM   #1
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
There are a few ways to determine your axle gear ratio:
1. Look for a tag under one of the diff cover bolts in the 9 o'clock position. This will tell you what ratio the Jeep originally had and likely should still have. If someone would have regeared it, chances are they would not put the tag back on. Here is an example of an axle tag you would find on a TJ axle:
2. Request a build sheet from a Jeep dealer. This will tell you the ratio the Jeep should have left the factory with. Build sheets can be wrong and axles can be regeared or swapped out, so I would not trust this much.
3. Jack up the rear end. Count driveshaft revolutions while rotating the tire. Turn the tire 2 complete rotations if your other tire remains stationary and does not rotate. Turn the tire 1 complete rotation if the other tire turns in the same direction. The number of times the driveshaft rotates equals the gear ratio. If the driveshaft rotates about 3x, the gear ratio is 3.07. If it rotates 3 3/4 turns, the gear ratio is 3.73. You can mark the driveshaft to help you count.
(see post below if interested why you spin a tire 1 rotation or 2 rotations)
4. Log your RPM at 60 MPH in a 1:1 transmission gear and plug the numbers in the formula below:
RPM x tire diameter
------------------- = Gear ratio
60 x 336
5. Open the diff cover and count the number of teeth on the ring and pinion gears. The number of teeth on the ring gear divided by the number of teeth on the pinion gear equals the gear ratio. The tooth counts will also often be stamped in to the side of the ring gear. For example, a 3.73 gear set is pictured below (41 divided by 11).
98 TJ
Wheelin98TJ is offline
Old 03-22-2009, 10:33 AM   #2
Wheelin98TJ
JEEP FREAK
So why do you sometimes spin a tire 2 complete rotations instead of 1 complete rotation?
The ring gear rotates 1 revolution each time that both tires make a complete rotation.
In other words, the 2 tires together must both make 2 complete rotations together.
If you have an open differential and the other tire remains stationary, the spinning tire must make both of the 2 complete rotations.
98 TJ
Closed Thread
Glock Forum
