#76 | |
All I know is from firsthand experience, I had a 1996 VW Passat VR6 with a Neuspeed P-flow and a K&N air filter on it; and whereas I did "feel" better acceleration and get better gas mileage from the car compared to my wife's nearly identical 95 VW Passat VR6, my car also threw CELs all the time where her's did not! I had to replace the MAF sensor several times (which sits right behind the K&N).
I would have to be a total idiot to run a K&N air filter on my LJ down here in dusty central Texas! All you have to do is look at the filter to realize it doesn't stop small particles from passing through it! The stock airbox and filters I use stop a lot of crap from getting into my engine, and the 4.0 I6 is pretty much bulletproof if you take care of it. Why screw up a good thing for a little temporary gain on an engine that was designed more for torque that acceleration?!?
#77 |
How does a K&N Filter help with better gas mileage?
4.0L TJ 5.7L CTS 3.7L KJ |
#78 | |
Do it right or not at all
![]() Join Date: Jan 2003
However, this is a Jeep forum... not a VW forum. The Jeep TJ was SPECIFICALLY designed to have a completely free breathing air intake. It is not restrictive in the least and this is right from Jeep engineering, not hearsay. So in the TJ's case, a free-er breathing air intake isn't going to help in the least. Since it's not restrictive, making it less restrictive won't help. What a K&N WILL do however is let a lot more dirt and dust into the engine. And to me, that is unacceptable. And since Jeeps are typically driven in dusty offroad environments, a K&N air filter is the very very LAST air filter I would run. ![]()
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#79 |
Purveyor of Funk
Any suggestions on another conical or cylindrical filter--in other words one that can be run in the cowl--that will provide a proper level of filtration?
#80 | |
#81 |
The most restrictive part of a Jeep TJ, Mustang 5.0L or any other engine is the throttle body. Not sure how a free-flowing intake can help with fuel mileage.
#82 |
Probably can't. Even a bigger throttle body probably won't work. Cold air works. Not much, but in my case 1-2 mpg improvement.
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#83 | |
a bigger TB does help a little bit with throttle response , mostly 1/2 to WOT transition when merging and such. I highly doubt theres much HP improvement (2% at 4500rpms maybe?), definitely no mileage improvement....i've been running one for ~2 yrs.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#84 |
You guys are thinking too much. I'm talking about how a high flow filter effects fuel efficiency when there is a partially opened throttle body that restricts the air already during most of your "economic driving."
#85 | |
![]() What YOU apparently failed to notice was that was entirely my whole point! The K&K was beneficial on my VW (and yes, I know this isn't a VW forum, thanks for pointing that out ) and most of us realize that it provides no benefits for the 4.0L I6.But thanks again for repeating the same comment for the umpteenth time, I think we all know by now that the K&N will suck in a lot of dirt and dust into the engine, you've repeated that comment so many times that it should be your signature block. Seriously, do you just like to post the same thing over and over again?!? |
#86 |
Purveyor of Funk
You made a post that extolled the virtues of CAI setups and claimed them as beneficial. To come back after the fact and say duh you obviously weren't saying they're useful on Jeeps everyone knows that blah blah blah, well... If we give you the benefit of the doubt, must assume that you're just a terrible communicator. Otherwise, it's nearly trollish.
#87 | |
Wanna Go Along?
Visit my website SyntheticLubeStore.com Dealer # 1468345 or email me gabe@syntheticlubestore.com Go to Amsoil's Online Store Use the application guide to see what you need Request more information about Amsoil & a Free Catalog |
#88 | |
#89 |
Exactly! Seems that everyone here convinced me that CAI is worthless, so instead, I went with the SDS (Supercharger Drive System) from RIPPMODS...picked up over 100 whp on my 3.8L JK
#90 | |
Purveyor of Funk
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
