FAQ - Cold Air Intake - Page 14 - JeepForum.com
post #196 of 341 Old 06-22-2010, 09:03 AM
mystangt
Originally Posted by MountainMan864 View Post
I have a quick question for all you CAI gurus. I have an airraid intake that came on my jeep. The filter is completly clogged with mud and dirt and looks like it has been stepped on and smooshed. I know you can clean those type of filters, but I am wondering if its better to go buy a new air filter and be easy on it. They make no paper air filters I can find that will find my airraid intake. Thanks guys.
What I would personally do is clean it up and make sure that there are NO holes in it (from being stepped on). Then separate any crushed fins (no need to go crazy, just open them a bit).
If there are no holes in, id let it soak in hot water and dawny for about an hour or so and then rinse it with a hose from the inside outwards, let it dry, oil it up (lightly) and pop it back in.
If its ripped however, just junk it and replace it...although they are $50-60.
Just as a reference point, I have had the same K&N that ive been carrying from car to car for about 5 years now. I clean it every 6 months and its been holding up fantastic. As a matter fact, I just put it on the new-to-me 4.0 TJ last night after washing it!
mystangt is offline
post #197 of 341 Old 06-22-2010, 09:08 AM
WillysEdition04
Originally Posted by bdock View Post
...but thats good research man. i just disagree. but if your ever in my town ill show you how much power difference it is.
... even my mom noticed the difference
Yeah, I disagree with facts all the time too. So what if the air mixes with the fuel well AFTER it passes the throttle body spacer? My mom says it looks cool! ...and moms know everything about automobiles. She even pumped her own gas once!
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
post #198 of 341 Old 06-22-2010, 09:21 AM
MountainMan864
The fins are all crushed and its semi flattened instead of round like it supposed to be. I can get a new one for around 40 bucks or so.
MountainMan864 is offline
post #199 of 341 Old 06-22-2010, 09:38 AM
mystangt
Get a new one and take care of it (unlike the PO) and it'll last ya for years to come!
mystangt is offline
post #200 of 341 Old 06-22-2010, 09:38 AM
WillysEdition04
$40 is cheap in the long run. I wouldn't chance it and just buy the replacement.
08 JK Unlimited
post #201 of 341 Old 06-22-2010, 09:40 AM
MountainMan864
will do thanks guys. Doing little things cause i might sell it cause im having a newborn son (first child woohoo) in september
post #202 of 341 Old 06-22-2010, 11:07 AM
mystangt
Congrats!!!
mystangt is offline
post #203 of 341 Old 06-22-2010, 09:28 PM
Wild Rye
OK, so I've got a K&N from the previous owner, not CARB certified so it won't pass smog. I don't mind going back to the stock air box but I'm not having much luck finding one. Any suggestions?
Wild Rye is offline
post #204 of 341 Old 06-22-2010, 09:38 PM
KKiowaTJ
IIRC all K&N CAI are CARB before they release them. Whats the problem? The filter or the whole thing? If its the filter go buy a cheap ricer paper one for the test. That or a buddy with a stock set-up and throw it on for the test and then switch back. Many ways around that problem, Good luck
MOPAR!
KKiowaTJ is offline
post #205 of 341 Old 10-24-2010, 05:15 PM
bandit455
I got a question for you guy's
How much cfm does a 4.0 need?
I'd like to use a donaldson pre cleaner on a cowl snorkel setup, but need to know which size to spec out based on how much cfm the intake will need to flow.
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #206 of 341 Old 10-24-2010, 10:24 PM Thread Starter
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
4.0L sucks about 385 cfm at WOT at redline. the stock throttle body flows about 450 cfm.
Source: 2000 Jeep Wrangler 4.0L Inline 6 - Stroker - Four Wheeler Magazine
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #207 of 341 Old 11-16-2010, 05:38 PM Thread Starter
Unlimited04
those that always reference the JP Magazine for Intake Shootouts should read this:
Sometime between the last test and this one, we had formed a working theory that it wasn't so much the air filter as the air tube that makes the power in these kits. With most, if not all, aftermarket air intakes, the air filter itself can flow more air than the Jeep can use. Sure, there are varying degrees of restriction from one filter to the next, but on a stock 4.0l engine we just aren't convinced that a significant result will be seen at the wheels from the air filter alone.
from their recent "Intake Shootout"
Jeep TJ Wrangler - Intake Shootout - Jp Magazine
Useful Write-Ups:
Funny:
post #208 of 341 Old 11-16-2010, 10:26 PM
2005X
i actually had a guy tell me he added 2.5 mpg and a few HP by adding a CAI and throttle body. he refused to listen to what i said.. he then said above 10,000ft is when he could really tell the difference.. i then asked him if he noticed it going down the moutain and he said yup!
2005X is offline
post #209 of 341 Old 12-30-2010, 12:32 PM
Moto4x4
So i should sell my Airaid cold air intake, and get a stock air intake and use the money towards other gear like new tires. Sorry i know this is kinda old but if anyone wants to answer, thats cool with me
Moto4x4 is offline
post #210 of 341 Old 12-30-2010, 02:12 PM
Bigbob
Bigbob's Avatar
Good idea. If you want a real cold air intake call the guy at Skinnypetal.com and ask him if he has anymore MCAI's available. I have the older version of this on mine and it works great. I can actually feel the power increase and it has the added advantage of filtering the cab air when you have the top on and it dual filters the intake air. It also gets the air inlet up a little higher.
This is the intake:
http://skinnypedal.net/store/index.p...roducts_id=108
He doesn't show the cowl scoop and filter, but call and ask.
The cowl scoop and filter was originally developed to just filter the interior/cab air so dust can be eliminated entering the A/C system and plugging the evaporator and heater core and had the added benefit of letting you breath better on dusty trails. Skinnypetal bought the idea from that guy but it could be it is no longer available. It used the stock Jeep air filter in the cowl vent.
Here is the cowl scoop and filter on mine.
I have the older intake design which uses a GM paper filter. The skinnypetal uses a conical filter.
I suggest you call or email them and ask.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
K&N Cold Air Intake vs AEM Brute Force Intake... anyone help? TJoshX TJ Wrangler Technical Forum 25 06-25-2011 02:19 PM
Cold Air Intake Imigorski YJ Wrangler Technical Forum 18 07-18-2008 11:30 PM
Cold Air Intake Imigorski YJ Wrangler Technical Forum 0 07-14-2008 11:17 AM
Cold Air Intake ?? gravelgrazer TJ Wrangler Technical Forum 14 04-24-2008 06:43 AM
Cold Air Intake-CAI CarsonKetrowYJ YJ Wrangler Technical Forum 2 03-18-2007 06:16 PM
