#151 | ||
Either way, if you drive long enough distance, the intake tube will eventually reach an average temp based heat transfer from the engine and outside air. You're best bet is a cowl or snorkel CAI, and wrap the plastic tube with some heat-resistant insulation, like header wrap.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#152 | |
If I do this it will definitley be something similar to the hummer set up or MCAI setup. Here's another question, Most of us know what throttle response is and can describe it,but what is the "mechanism" behind it? Is it due to more efficient combustion due to denser air (more air) being introduced into the cyclinder?
05 Unlimited 4x4 Quote:
#153 | |
Introduction: Throttle response - Wikipedia, the free encyclopedia the technical stuff is covered on page 8: http://www.jeepforum.com/forum/f9/faq-cold-air-intake-558437/index7.html#post7833663 Basically imagine if you have no manifold at all - the engine wants to turn at max rpm constantly because it is sucking in as much air as it can use. A prime example is when people don't get their intake manifold seated on the gasket properly when removing the intake and exhaust manifolds. The manifold is basically wide open - there is no restriction, the engine instantly revs full throttle. To modulate this, we have an intake manifold and a valve that limits the amount of air that enters the engine. This valve can be a throttle body or a carb, they function in the same manner we're talking about here - strictly air modulation on an air pump. When you open the valve wide open, the engine goes to max RPM. The time it takes it to do that is throttle response. Whenever you put your foot on the pedal, you're modulating the amount of air entering your engine. The restriction of the air pump creates vacuum - a suction. The vacuum is what powers your brakes for example. A bigger valve and bigger manifold allows more air to enter the engine - in other words - you are more closely approximating no manifold. This means the vacuum decreases. Decreased vacuum = less pressure difference across the manifold = increased throttle response. Well, sorta...a bad explaination for the race techies in the crowd, but its an OK way to think of it. This doesn't automatically mean you make more horsepower or torque - it just means you're more closely approximating no intake manifold in less time. On engines that don't have a particularly restrictive intake manifold, like the 4.0L, there will be minimal power gains. Any power gains, if any, will be at RPMs where air flow is the limiting factor to approximating that no manifold thing - high RPMs. However, throttle response will be improved because you are now allowing more air past the valve for every increment you open it. This is shown in the math by the very slight difference in pressure between a 58mm and 62mm throttle body. And that throttle response/pressure difference is slight on the stock 4.0L. Not worth $300 to me, but it was worth ~$80-90 for an Ebay throttle body. It depends on your preference. But there are always better things to spend your money on.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 11-12-2009 at 12:56 PM.. |
#154 | |
Thanks for the explanation Unlimited04. So, bringing temperature into the discussion again. The reason I feel the increased throttle response is due to the cooler air being denser, thus bringing in more air, simulating the "no manifiold condition". Is this correct?
#155 |
sometimes when I put my jeep into park and let off the gas it decides to idle around 2500 rpm which is high for it being in park. it doesnt happen often, but could this be a problem with the intake manifold that you were talking about and the rev problem?
UNC-Charlotte Mechanical Engineering |
#156 | |
Using the calculator described on page 7 - Throttle Body Sizing Calculator | REVTRONIX Test the extremes: 20* F = 0.24 psi, 320 CFM 175*F = 0.18 psi, 320 CFM So on a 155* F temperature swing there is a 0.06psi difference due to air density. Theres also a difference in fuel delivered, which I have no idea how to measure or speculate on, especially considering the PCM's propensity for rich-lean A/F behavior depending what RPM & loop we're talking about. Obviously more fuel + more dense air = more power. If you're drag racing it makes a world of difference, but in the context of the 4.0L, who cares. ![]() Thats pretty much the idea - who cares - the 4.0L isn't a wicked performance engine - its a tractor motor. Put paper filters in it for $5-10 each and be happy knowing you're keeping junk out of the engine. End of story! no thats and electrical/computer problem. Most likely your IAC or TPS.
#157 |
Restoration Complete
That statement is debatable...I only have about 3000 miles on my Stroker so it's really not broken-in. However, my mileage is probably no worse than a stock 4.0L.
'98 Wrangler Sport, 4.6L Stroker 12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Venom Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Screamin' Demon Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust. Balanced Rotating Assembly. Yeah, I built it! '04 Mustang GT, 4.6L Light modifications Read more, Post less, Search often |
#158 |
Maybe you don't need to rev as high and/or throttle it as much as before? Would be nice to think a stroker (or the awesome 4.7 crate motor discussed) could get approx the same MPG.
#159 |
Cold air warm air whatever. Bottom line where the air intake is sucks water. A paper filter is junk after it gets wet. I plan on moving my air filter under cowl as suggested by unscathed DIY project. http://articles.jeepforum.com/Tj_Cowl_Induction_Snorkle. A regular filter won't fit. I am going to leave the old filter box where it is plugging the holes and using it as a tool box. Have a nice day.
#160 | |
Friends don't let Friends run Bosch My Wifes Cake Site - Check the Jeep Under Carved & 3D |
#161 | |
The newer JP link you cite shows stock HP/TQ at 142.3/188 and gains ranging to 154/200.9. That's a potential gain of 11.7/12.9 (or ~double your cited 6/4). It's quite possible those are high-RPM gains, but that article doesn't seem to include any charts or numbers to verify. |
#162 | |
#163 | |
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#164 |
tttttttttttttttt
#165 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
