Quantcast FAQ - Cold Air Intake - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > FAQ - Cold Air Intake
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 05-14-2008, 03:06 PM   #1
Unlimited04
Unlimited04's Avatar
I've started this thread so the info can be added to the FAQ or stickied in some way.
The question is frequently asked: "Do cold air intakes make a difference?", whether this be improving gas mileage or improving performance.
the simple answer is NO. If you're interested why, read further.
The K&N Problem:
ISO Coarse Dust Test of multiple brands of air filters - K&N clog faster and passes 3-4x more dust than paper filter:ISO 5011 Air Filter Test Report
They state: "Compared to the AC Delco air filter, the K&N plugged up nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt."
Fine dust passing through a K&N in the stock TJ airbox:
How good are K&N filters?
Why does this matter? Dust = silica. Read about silica here:
Recognizing the Signs and Symptoms of Silica Contamination from Practicing Oil Analysis Magazine, January 2006.
The UOA (used oil analysis) with observed silica content in street driven vehicles:
Threw away K&N's due to high silicon in UOA's - Bob Is The Oil Guy
Cold Air Intake Design:
There are three main types:
1. Stock intake tube cut with a K&N style filter from Autozone clamped on the end.
2. An aftermarket tube, usually larger in diameter than stock, with a K&N style filter clamped onto it. Many utilize a 'heat' shield, and some such as the AEM "Dryflo", utilize a "dry" filter instead of the "oiled" types.
3. Other intake options use a snorkel of some type (covered later).
Performance Gains:
Here is a dyno test performed by JP Magazine:
Jeep Wrangler TJ Inktake Dyno - A Day On the Dyno - Jp Magazine
Notice they showed a gain of 6 hp and 4 lb-ft of torque at around 4500rpm.
Here's a link to a 18 comprehensive dyno runs comparing the stock intake, no intake at all and an aftermarket cowl intake.
http://www.tricktuners.com/forums/showthread.php?t=226
He saw absolutely no statistically significant difference between the runs. And to actually show how easy it is to skew a dyno, he saw a near 10 hp increase just by changing tire pressure.
Have you ever wondered what the Jeep Engineer's would have to say about the stock intake vs a CAI?
well, read about that here: JeepEngineers on Cold Air Intakes.
So What Do We Know about Cold Air Intakes:
Pros:
1. Eliminates stock airbox (may be necessary for custom fenders)
2. Improved HP and TQ by about 2-3% at ~4500rpm (Engine max: 5200rpm).
Cons:
1. Expensive - brand name kits cost around $150+
2. Cleaning - open element filter is exposed to much more dirt, mud, dust and debris from engine compartment.
3. Thin film of dust typically passing through filter, thus the engine is exposed to this dust.
4. Oiled filter versions further attract dust, dirt and debris.
5. Due to inadequete filtering, a Outwears Pre-filter, or similar filter sock is required, further adding to cost.
6. Requires frequent cleaning due to dirty environment - typical cleaning kit costs $20+.
7. Increases risk of hydrolocking - exposed element can suck water into engine easily.
8. Noise - annoying "sucking" noise can be heard, sometimes associated with a loud whistle.
9. Dirty filter can cause rough and/or high idle.
I used to run an AEM intake, but removed it after finding a lot of problems associated with it. I documented my observations here: AEM Intake observations
The Snorkel:
There are also many brands of snorkels, designed to prevent water from getting into the engine, and to introduce air from outside the engine compartment. Brands include ARB, Volant, and others. Many people construct their own snorkel systems using PVC pipe and 1990's Buick intake boxes.
Pros:
1. Introduces air from outside the engine compartment
2. Elevated air intake to resist hydrolocking engine during deep water crossings.
Cons:
1. Expensive - ARB, Volant, etc brand intakes cost over $300.
2. Most require extensive modifications to the stock airbox, or a new airbox.
3. Modifications often require drilling and cutting of the body - could lead to rust, or water leaks.
4. Often times the windshield cannot be folded down.
Better, True CAI & Snorkel Write ups:
Buick/Hummer snorkel #1: TJ Hummer Intake Write-up (Buick Airbox)
Buick/Hummer snorkel #2: Write-up for a Hummer cold air intake
Low buck Buick airbox: Buick Airbox instalation
Homemade Cowl CAI #1: My Final Word On Cold Air Intakes
Homemade Cowl CAI #2: Cowl Induction - snorkle (WRITE UP)
Another cowl intake: Cowl Induction - snorkle (WRITE UP) - Page 4
Autozone Cowl intake: http://www.jeepforum.com/forum/f9/cold-air-intake-860538/
Buick airbox mounted directly to the throttle body: http://www.jeepforum.com/forum/f9/i-am-liberated-863818/
Homemade snorkel with K&N: http://www.jeepforum.com/forum/f9/homemade-snorkel-intake-w-pics-910113/
My personal favorites:
Windstar Airbox Cowl Intake: http://www.jeepforum.com/forum/f9/cowl-intake-windstar-air-box-566973/
Windstar Airbox Cowl Intake #2: http://www.jeepforum.com/forum/f9/windstar-cowl-intake-1064377/
Mustang Air box CAI: Mustang GT Air Cannister
Homemade Aluminum Snorkel: homebrew aluminum snorkel
Unlimited04 is offline   Reply With Quote
Old 05-14-2008, 03:14 PM   #2
Unlimited04
Cost Effectiveness:
$250 for a cold air intake system
- this will get you about 20,000 miles before requiring cleaning
$20 for cleaning kit
- this will get you about another 20,000 miles
In contrast, for the stock airbox:
STP paper filter cost from Autozone: ~$5
This means for the $250 the CAI cost, you could have bought 50 STP paper filters. Considering you can get about 6,000-9,000 miles from each paper filter, that means you could travel at least 300,000 miles on $250 of paper filters.
For the oiled filters, for the $20 for a K&N cleaning kit, you could travel 24,000 miles on paper filters.
For the cost of one CAI, and one cleaning kit, used to travel approx. 40,000 miles, you could travel 324,000 miles on paper air filters.
It is simply not cost effective for 3% in power gains @ 4500rpm to jeopardize your engines health, or to waste money on expensive filters mechanisms.
Old 05-14-2008, 03:21 PM   #3
Silver04TJ
Nice
Now we just need one for:
Throttle Body Spacers
Hi Lift mounts
How to increase MPG and power
etc
etc
etc.
Silver 2004 Jeep Wrangler Sport
3.5" Rubicon Express Standard lift,
Cepek DC-1 15x10 Black wheels,
33x12.5x15 Cepek Fun Country II!!
M8000 Warn Winch with in cab controls
And the accessory every Jeep should have...DIRT/MUD!
Silver04TJ is offline   Reply With Quote
Old 05-14-2008, 03:30 PM   #4
robplumm
K&N cleaning kit is 9.99. You get multiple uses out of it
robplumm is online now   Reply With Quote
Old 05-14-2008, 03:30 PM   #5
Unlimited04
I documented my observations on the AEM Throttle body spacer and a 62mm bored TB here:
http://www.jeepforum.com/forum/5116179-post16.html
My google search has shown each kit costing 19.95 from three different websites. My AEM intake was so dirty after 25,000 miles, I used the entire cleaning kit provided by AEM. I purchased a K&N Recharge kit, which is now 1/2 empty to clean the filter again at 30,000 miles. Every time the filter was cleaned it was caked with dirt, dust, mud and debris, resulting in high engine idle (900-1200rpm) and rough idle (sputtering).
Old 05-15-2008, 08:37 AM   #6
Dirt Surfer
This is excellent info. I have always known the filters offer little bang for the buck. Especially where I live at high altitude.
What I would really like to know, is some definative answer as to the benefits to a true cold air intake. Moving the filter to the cowl is relatively easy, or you can use a snorkel. In theory there is supposed to be an advantage, but I want to know what is real life numbers.
I want to do a cowl induction and also install vents in my hood, I wonder what the real benifits would be.
Built 2000 XJ sold for a...
2004 TJ Rubicon. 4.0L/auto with stock 4.10s on 33s. Full JKS lift with OME shocks and DPG springs. (DPG Super Ulti.) 1.25 BL and MML and 1350 rear CV. Jeep Medic full belly skid, Rokmen rails, Riddler diff covers.
Dirt Surfer is offline   Reply With Quote
Old 05-15-2008, 10:50 AM   #7
Bigbob
Bigbob's Avatar
Good info. But. It is not a "cold" air intake unless it gets the air from someplace other than under that hot hood IMHO. I think AEM calls theirs a "Cool" air system, it may be someone else. You will not see any significant power gains unless you are actually getting cold air. This means air from elsewhere than under the hood and an insulated intake pipe. Most, if not all intakes they sell on the after market pick up air from the same place the stock system does. All that hot radiator air is coming right into the intake. Some of the systems put a dam affair in there, but I seriously doubt it is very effective. I am not knocking any intakes out there, but I would not call them a CAI unless they were getting the cold outside the hood air. My intake is sealed off from the hood and pulls air in from the cowl. The intake tube is also insulated. My "seat of the pants" dyno was very impressed. I would love to see dyno readings on this system. I have not checked mileage yet, but others are averaging betwen 50 and 70 more miles per tank. If they can get the price right on this deal it'll sell like hotcakes. It also filters the A/C air so the cab and vents stay cleaner.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 05-15-2008, 11:21 AM   #8
Dirt Surfer
Pics, pics, pics....
I would also agree the intake tube needs to be insulated. Plastic is not as conductive as those nice shinny thin aluminum ones. Not only that, but the intake it's self is very condustive and stays quite hot. On my XJ I insulated my header and the bottom side of my intake trying to keep the exhaust heat away. Honestly, I don't think it helped any. The underhood temps were still hot and the aluminum intake bolted to the block seemed to be just as hot as before.
So again, the cowl intake and hood vents sound good in theory, just not sure what it will amount to when I'm done.
Old 05-15-2008, 11:29 AM   #9
JeepGirl04
JeepGirl04's Avatar
2010 JK Wrangler
OK sooooo
Bear with me on this cause Im a newbie trying to figure things out...
From what I am reading... there is no need to put anything other than the K&N air filter I have on there ( which did put the purr back in my engine) ...
JeepGirl04 is offline   Reply With Quote
Old 05-15-2008, 11:40 AM   #10
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Originally Posted by JeepGirl04 View Post
OK sooooo
K&N filters are frowned upon here too.
TheBoogieman is offline   Reply With Quote
Old 05-15-2008, 11:43 AM   #11
JeepGirl04
JeepGirl04's Avatar
2010 JK Wrangler
huh?
ARGH! What is the reasoning behind that?? They seem to work great?
Old 05-15-2008, 11:45 AM   #12
TheBoogieman
Demonic Jeep Freak!
People just have their own opinions and some factsHere's the best quote on them.
"The added dust and fine particulates a K&N has been found to pass when compared to a paper element filter like from AC-Delco makes the K&N a very poor choice in my opinion. Beyond that, it won't give better mpg or performance despite what their wild marketing claims say. This has been well proven in studies that have been shown and discussed here before. One study shows the K&N passed 18X more dirt & clogged up 3X faster than an AC-Delco paper air filter if I recall correctly."
Old 05-15-2008, 11:49 AM   #13
JeepGirl04
JeepGirl04's Avatar
2010 JK Wrangler
Ok Boogieman...so then what in your opinion is the best solution when your engine is running a lil rough, assuming all fluids are where they should be and the oil is freshly changed...
Old 05-15-2008, 11:52 AM   #14
TheBoogieman
Demonic Jeep Freak!
If the spark plugs are wires are good,I would clean the TPS and IAC.
http://www.jeepforum.com/forum/showthread.php?t=489089&highlight=cleaning+IAC+jer ry+bransford
Old 05-15-2008, 12:02 PM   #15
mike_dippert
hodophobic
mike_dippert's Avatar
you have Mac's thing?
Bestop LJ Halftop for sale. Warm up the cabin faster in the winter!
Jeepiki, the Wiki just for Jeeps
You can't argue with ignorance.
Originally Posted by HurricaneRZA View Post
JF taught me that the 2.5L, Ax-5 and D35 together are so powerful that angels weep when I shift into 4LO.
The only thing a bicycle inner tube is good for, is tying a knot in the end of when you run out of condoms.
mike_dippert is offline   Reply With Quote
Glock Forum
