Quantcast FAQ - Coil spring measurements - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > FAQ - Coil spring measurements
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 11-27-2008, 07:38 PM   #1
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Below are the approximate heights of various TJ coil springs when sitting at ride height with the weight of the Jeep on them. The measurements are from the very top of the spring where it meets the isolator or coil bucket to the very bottom of the spring (again where it meets the isolator or coil mount).
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 11-27-2008, 07:43 PM   #2
never monday
NICE!!!
Let's add if you have a larger than normal isolator. You'll need to add that measurement to the spring height to get the lift amount.
Get Savvy
never monday is offline   Reply With Quote
Old 11-27-2008, 07:51 PM   #3
Wheelin98TJ
JEEP FREAK
Originally Posted by never monday View Post
NICE!!!
somewhere If I can find it I had a list of many of the aftermarket springs. Give me a few days....
Thanks for providing the measurements for stock springs and thanks for the suggestion to add this info to the FAQ.
At one time I also had a spreadsheet that I made based on email and phone calls to manufacturers. It had all kinds of info on aftermarket TJ coil springs including spring rate and measurements, but I gave up on it since I was sometimes getting conflicting info depending on who I spoke with at the company. I guess some manufacturers do not like to give out this info.
98 TJ
Old 11-27-2008, 07:52 PM   #4
never monday
but wait, theres more
Get Savvy
Old 11-27-2008, 08:04 PM   #5
never monday
found it
From Rubicon Express customer service email to T.N. (November 2004):
The 3.5" TJ fronts are approximately 240 pounds per inch. Uncompressed free
length is 19"
The 4.5" TJ fronts are approximately 219 pounds per inch. Uncompressed free
length is 19.75"
XJ front springs
OEM is supposedly 147 lb/in rate.
Tera 4" TJ coils give 4.5" of lift on an XJ and have a 200 lb/in rate , 20.25" tall unloaded
Tera 3" TJ coils give 3.5" of lift on an XJ and have a 170 lb/in rate
Rusty's 4.5" coils give 5" of lift and have a 150 lb/in rate, 22" tall unloaded
RE's 4.5" ZJ coils give 6"-6.25" of lift on an XJ and have a 200 lb/in rate, 22" tall unloaded (RE ZJ coils are 240 lb/in)
Rustys 3" coils give 3" and have 150 lb/in rate.
Rancho 3" coils, at least the old coils give about 2 1/4" of lift on an XJ and have a very high 235 lb/in rate
Rancho 3" coils, at least the old coils I had give about 2 1/4" of lift on an XJ and have a very high 235 lb/in rate.
OME coils give 2.25" - 2.5" of lift and have a 148 lb/in rate
OEM Old man EMU XJ is supposedly 142-147 lb/in rate. 17" length 5.25" diameter
OEM ZJ with 4.0 is supposedly 190 lb/in rate front and rear.
OME 930 coils: 160 lb. spring rate. 1.75" of lift on XJ
OME 934 coils: 180 lb. spring rate.The 934 spring is 35 mm (1.37") longer than the 930 spring.
The 930 is listed as a XJ or ZJ I-6 spring and the 934 is listed as a ZJ V-8 spring but is also used on the XJ. the 934 should give about 2.5in lift.
Tera 4" TJ coils have a 200 lb/in rate , 20.25" tall unloaded
Tera 3" TJ coils have a 170 lb/in rate
RE Rubicon Express 4.5in ZJ coils are 240 lb/in. give 5.5" ish of lift on an XJ 22" tall unloaded
RE 5.5XJ coils are 4.5ZJ coils.
Rusty's 6.5" 22" long, 12 wraps of 5/16" stock
Rancho 3" coils, at least the old coils give about 2 1/4" of lift on an XJ and have a very high 235 lb/in rate.
Rockkrawler 6.5" are 165 lbs/in
SJ Sky Jacker 3" ZJ coils 218 lbs/in
SJ 6in XJ RR coil is 13 coils and same height and thickness as the RE ZJ4.5in XJ5.5in coil.
Get Savvy
Old 11-28-2008, 12:08 AM   #6
mudb8
want it rite or rite now?
mudb8's Avatar
thanks guys, just saved me a bunch of time!
any info on clayton springs? I was just trying to find the unloaded length of 4.5" xj springs...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 11-24-2009, 11:47 AM   #7
lukethedork
Just saw this thread again while I was searching for GC spring rates. Didn't see it listed in the 'TJ Forum FAQ' sticky thread at the top.
As Joe Budden would say, (B)Pump it up.
lukethedork is offline   Reply With Quote
Old 05-15-2010, 11:03 PM   #8
never monday
added from another thread
In shore BDS lifts from 2" to 4" are:
BDS = Front 158 lbs.................... Rear 200lbs
For OME I found the Nov 2009 update catalog. It has everything from spring rates, wire diamater, number of coils, free height etc.. It also includes shock sizes and other infor. Here is the link were I found the pdf of the catalog.
http://www.jeeptoys.ru/2/!OME%20Cat%2024%20EXPORT%20Nov09%20Update.pdf
Here are the main TJ/LJ rates and the OE rates as indicated in the catalog.
OME #.......... Spring Rate lbf/in........OE Spring rate Lbs
OME930.............162...........................1 40
OME931.............140............................ 140
OME932.............140............................ 140
OME933..............140........................... .140
OME934..............160........................... .140
OME949..............216........................... .160
New Table with extra info:
Spring ……….Diameter……Length A….Length B…….Rate……OE Rate
Front:
OME9330………..551……….19.49……….19.09……….140……….140
OME934……….0.5511……….20.08………19.68……….160……….140
2" BDS 034204…..0.563……….18.5……….18.5………158……….140
3" BDS 034302…..0.563……….19.5……….19.5……….158……….140
Rear:
OME941……….0.5905……….15.35……….14.76………. 140……….140
OME942……….0.6102……….14.96……….14.37………. 160……….140
OME949………..0.669……….14.57……….13.98……….216……….160
2" BDS 034206…..0.625……….13.75……….13.75……….200……….160
3" BDS 034308….0.625……….14.75………14.75………200……….160
Get Savvy
Old 01-26-2011, 10:47 AM   #9
imlikeojnow
so i have 14 inch springs and a two inch spacer thing. so i guess it is 4 inches of lift. nice. can i just get 6 inch springs and put in there or is there alot more to it than that?
imlikeojnow is offline   Reply With Quote
Old 01-31-2011, 02:37 PM   #10
Unlimited04
Unlimited04's Avatar
I was confused by some discrepencies above, so I got these from ARB directly...
Code:
Part#    height mm A/B           spring rate lbf / in
OME932     480/470                      140
OME933     495/485                      140
OME934     510/500                      160
Unlimited04 is offline   Reply With Quote
Old 02-02-2011, 10:20 AM   #11
Wheelin98TJ
JEEP FREAK
bgmadmxr posted the thread below that has a link to the OME parts catalog and it includes technical specifications on their suspension parts.
OME spring / shock specifications found
98 TJ
Old 04-30-2011, 06:48 PM   #12
dcope17
dcope17's Avatar
How about a different measuring point cause someone might have coil overs... say stock bumper height with X size tires. Or even point on frame to ground or axle...
1.) Jesus 2.) Wife
3.) Jeep 4.) myself
dcope17 is offline   Reply With Quote
Glock Forum
