Fan speed switch - JeepForum.com
post #1 of 12 Old 10-11-2012, 06:52 AM Thread Starter
kymater
Fan speed switch
Trying to figure what's wrong. I only have the 3rd speed on my fan speed. I've read countless articles where the resistor goes bad and you only have the High speed, but that is not what I have. What could be my problem?
thanks
kymater is offline
post #2 of 12 Old 10-11-2012, 06:54 AM
TheRealKTrain
JK Wrangler
Most likely the resistor. They dont all fail the same.
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #3 of 12 Old 10-11-2012, 07:03 AM
JBTJ
When my 3rd speed went out it was the switch.
JBTJ is offline
post #4 of 12 Old 10-11-2012, 08:55 AM
mdm
Farm Wheeler
The blower control issues are caused by the blower motor. Over time the motor will start drawing more current because of dust and grime building up in the motor making it harder to turn. The higher current draw can burn out the elements of the resistor and/or damage the wiring and switch. Take a look at the back of the switch. You'll likely see melted insulation and wiring.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 12 Old 10-11-2012, 09:51 AM
JBTJ
While this is true to a point. The weakest link always goes first. The switch, only rated for 10 amps controls a 30 amp blower motor . I was melting switches and resistor packs until I did the relay mod. Did not replace the blower motor and no more melting parts, switch or resistor pack. That was 6 years ago.
JBTJ is offline
post #6 of 12 Old 10-11-2012, 10:10 AM
mdm
Farm Wheeler
I've replace the resistor twice in the past seven years. Last winter the switch ate itself. I'm going to insert relays into the circuit before winter sets in for good.
mdm is offline
post #7 of 12 Old 10-11-2012, 01:54 PM Thread Starter
kymater
Well, took it all apart today. It is definitely the blower control switch this time. I simply removed the switch and started crossing wires.....all fan speeds are there. I also noticed some melting around the blades in the switch. I've got a new switch on its way.
Anyone know of video or a step by step article on the relay modification? I've seen the one from Jp magazine, but I'm not that electrical inclined to figure it out from the article.
kymater is offline
post #8 of 12 Old 10-11-2012, 02:02 PM
JBTJ
When I get back to the house I will post how I did mine for ya.
JBTJ is offline
post #9 of 12 Old 10-11-2012, 02:03 PM
JBTJ
You can also search something like "fried blower motor switch" and find a ton of info.
http://www.jeepforum.com/forum/searc...rchid=16665358
JBTJ is offline
post #10 of 12 Old 10-11-2012, 05:55 PM
Squint77
Squint77's Avatar
Make sure you take out your fan as well and clear it of any leaves or debris. This should help prolong the life of your resistor and switch, but like mentioned above, it is just a poor design.
Greg
(Soft top info:
Squint77 is offline
post #11 of 12 Old 10-13-2012, 12:44 PM Thread Starter
kymater
thanks for the replies.....new switch came in today. I think I will try to tackle the relay mod before I stick it in.
kymater is offline
post #12 of 12 Old 10-13-2012, 01:33 PM
JBTJ
I would install the switch first. Just to make sure all is working properly.
JBTJ is offline
