Fan on high????? WTF - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Fan on high????? WTF
Black Friday Sale - Deep Discounts from ExtremeTerrain.com6th Annual, Beat Your Wife to the Credit Card Sale!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 08-07-2014, 08:55 PM   #1
S10fcphs
Greetings All,
My fan in my 05 rubi for some reason is stuck on high. It will
blow on high on the first 3 settings than shuts off when selector
is on the high setting..?? unless fiddled with than high on all
I just replaced the blower motor resister and it still has this
issue..
I did notice a clicking that came from the fan itself for a bout 10 min
2 weeks ago and I think it has been like this on high from that time
forward...
I had the AC on high and never noticed this till I went to use it on a lower
setting...
Any thoughts would be awesome
S10fcphs is offline   Reply With Quote Quick reply to this message
Unread 08-07-2014, 10:17 PM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Fan speed switch damaged internally from being overheated?...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 08-09-2014, 12:02 AM   #3
S10fcphs
That was my next guess....
From what I have been told buy the stealership I will have to replace
all 3 because there is not just one switch for the 05 06 its the whole thing
and was discontinued from jeep. Not even a part number..
Its 174 is if I get it there..
Figures
Looks like its on high for me for a little while longer..
Unread 08-09-2014, 02:42 AM   #4
sd05tjjeepb
Theres at least one up on amazon at 118$. Probably still more then you want to spend, but still less then the dealership.
sd05tjjeepb is offline   Reply With Quote Quick reply to this message
Unread 08-09-2014, 12:49 PM   #5
Rubi4MyMrs
Tks 4 the upgrade MoodyJP
Rubi4MyMrs's Avatar
According to these guys you can use the earlier switch (’99-’04) with maybe slight modification & not get the whole panel.
http://www.jeepforum.com/forum/f9/20.../#post22609977
http://www.jeepforum.com/forum/f9/re.../#post22855001
Rubi4MyMrs is offline   Reply With Quote Quick reply to this message
