Fan Clutch bad? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Fan Clutch bad?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 09-06-2014, 12:43 PM   #1
blase116
Fan Clutch bad?
Was just wandering what your guys opinion is, (as I hate replacing things that are not needed).
The back of the fan clutch looks like it lost its gasket and there are not bearings all the way around inside the housing. It is not seized as it still rotates but it is pretty hard to turn (regardless of being cold, started cold, or hot.)
If I do need a new fan clutch any opinions on what kind to buy or what kind not to buy.
Thanks!!
Blase
White 97' Jeep Wrangler Sport 4.0/ 5 Speed
blase116 is offline   Reply With Quote
Unread 09-06-2014, 12:55 PM   #2
realbadlarry
just my humble opinion, but if you can see the bearings...they are not long for this world....friction=heat=wear=failure. Metal on metal with no lubrication is not good. I'm not sure on the brands, I think some people like OEM stuff..I would try to find new and stay away from remaned stuff.
realbadlarry is offline   Reply With Quote
Unread 09-06-2014, 02:03 PM   #3
WhiteMtnJeep
The Punk Made My Day.....
WhiteMtnJeep's Avatar
Yup, looks like it's on the way out. Best case scenario it seizes and the fan just turns as fast as the shaft. Worse case scenario it grenades and takes out the radiator and whatever else as well..
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Polyphase Meterman IBEW Local 387
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
WhiteMtnJeep is offline   Reply With Quote
Unread 09-06-2014, 03:04 PM   #4
chris142
ya its dun
chris142 is offline   Reply With Quote
Unread 09-15-2014, 11:02 AM   #5
blase116
Replaced over the weekend , it spins a lot easier now. Drives better too, I imagine it freed up a few hp. Thanks for the help!
Blase
