Fan Belt / Pulley Tensioner - JeepForum.com
post #1 of 4 Old 05-06-2008, 04:33 PM Thread Starter
feusaf
Looking for some technical expertise...
Change the fan belt this evening on my '97 TJ 2.5L and discovered something interesting. The bolt to adjust the tensioner just turned and turned and turned, and would not adjust the tension of the pulley. My mirror handle is pointing at the bolt in question...
Reached my hand around the backside of the bracket and realized that there is nothing securing the bolt to the bracket to allow the pulley to go up and down. Am I missing something here, or should I be able to adjust that tensioner?
If this thing is broke, could someone give me a part # to research through Autozone/NAPA or Mopar? And, if I can replace the missing part, can I do so without replacing the whole bracket?
One last question, if you were troubleshooting a squeal out of the fan belt and it wasn't the belt, would you go for the pulleys or the alternator? The alternater is showing 13.6v or higher on my meter, so I know it's good. Not sure if I can replace the pulley on the darn thing.
Much thanks,
Jim S.
Bonaire, GA
Jim S.
Bonaire, GA
1997 TJ 2.5L
feusaf is offline
post #2 of 4 Old 05-06-2008, 04:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You have to loosen the big bolt (that brown one in your photo) the idler pulley rotates around first before the idler pulley will move up and down in its slot.
Jerry Bransford is online now
post #3 of 4 Old 05-06-2008, 04:45 PM Thread Starter
feusaf
Well, I guess I opened myself up for that one...actually, I did loosen that bolt up (the one on the pulley), but the idler pulley only adjusted up and would not adjust down to get the tension right. The more I cranked on it, the more it would stick out of the bracket
I actually took the adjuster bolt out of the bracket to see if it had threads on the very end that I could stick a nut on to get it to adjust. Ended up doing it the old fashioned way. Tightened the pulley down and beat it with a mallet until the tension was right !!!
Jim S.
Bonaire, GA
1997 TJ 2.5L
feusaf is offline
post #4 of 4 Old 05-06-2008, 10:37 PM
prd_cdn
prd_cdn's Avatar
There should be a small block the bolt (you point too) should be attached into. The other bolt, as mentioned, also bolts into this same block. Becareful removing the screws, getting them to line up is a PITA.
Beware the bolt you point to, has a small pivot point and when screwing that bolt down you want make sure it protrudes out the hole, the body of the pully, This hole is just big enough for the end of the bolt.
I had the same problem, I loosened them both to the point I felt they would come right off. Then with one hand, I lift up the idler and the other screwing in the bolt (the one pointed too), then just keep lifting and tightening to the point your happy. Then tighten down the pully bolt down.
This is what I have found, this is what worked for me ~ so good luck .. hopefully this helps some what.
prd_cdn is offline
Manual belt tensioner question... missing tensioner bolt? JFamily TJ Wrangler Technical Forum 22 03-23-2016 10:13 AM
Tensioner pulley problems Wrangler_91 TJ Wrangler Technical Forum 1 01-05-2010 04:42 PM
Belt Tensioner Pulley (manual) miltownTJ TJ Wrangler Technical Forum 3 12-01-2009 08:25 AM
Tensioner Pulley Replacement Skeezer TJ Wrangler Technical Forum 3 12-30-2006 08:56 AM
Tensioner pulley NCjeeps TJ Wrangler Technical Forum 2 11-02-2004 06:22 PM
