Failed Colorado Emissions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Failed Colorado Emissions
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 03-31-2011, 02:45 PM   #1
LaddieHanus
97 TJ 4.0 Automatic 130,000 miles
Took it in to the test station last week after changing the oil and air filter.
HC 1.306 Limit 1.200
CO 18.8110 Limit 15.000
NOx 6.6770 Limit 3.000
Replaced the spark plugs and the O2 sensor on the ex manifold and took it
in today
HC 1.3029
CO 18.4293
NOx 6.2924
In the last 2 years since it passed I have rebuilt the transmission and replaced the radiatior. Before this it sat a lot because the tranny was in bad shape.
The High NOx numbers have me confused otherwise I would just replace the catalytic Converter. The entire exhaust including the converter was replaced about 9 years ago when the mainifold cracked in a number of places and I put on a Borla header and catback.
Anybody got any ideas? I was planning on a V8 swap this summer but it would be nice to have this running till then.
Laddie Hanus
LaddieHanus is offline   Reply With Quote
Unread 03-31-2011, 05:14 PM   #2
bluefox_gt
Alot of the time aftermarket coverters stop doing there job faster than OEMs. The NOX is pretty high. Try checking the PCV valve or check the header and exhaust for air leaks. Run some seafoam or injector cleaner through it. When have your T-stat been changed?
That isn't mud, it's a jeep beauty cream and the smell well, it'll go away when it drys..
bluefox_gt is offline   Reply With Quote
Unread 03-31-2011, 05:52 PM   #3
SilverTJMike
Was it good and hot, usually helps, and not drive down the road hot but drive down I-25 hot? One of my cars failed, the mechanic took it back and it passed, he just warned it up.
SilverTJMike is offline   Reply With Quote
Unread 03-31-2011, 05:59 PM   #4
dm0ney
My wife's 4Runner failed due to high NOx (4.5573) and it turned out to be the catalytic converter. (Well I assume that, since we replaced the new catalytic converter and then it passed.) The shop we took it to said the majority of the time they see high NOx it is the catalytic converter.
However her HC and CO readings were both well under 1.0, unlike your readings, so maybe you've got something else going on. Not to mention possible differences between a 4Runner and a Jeep. But I figured I'd mention it anyway.
dm0ney is offline   Reply With Quote
Unread 03-31-2011, 06:07 PM   #5
freeskier93
"Generation Dead"
freeskier93's Avatar
I bet its your cat. I went through this same thing exactly. Replaced o2 sensors, spark plugs, oil, etc...
Pulled out my emissions reports, I kept failing at:
20.9 PPM CO2
1.23 HC
Brought it to a mechanic who hooked it up to their computers, they said the o2 sensors were reading the same thing, indicating the cat was bad. Replaced the cat and dropped down to 5.6 PPM CO2 and .5 HC. NOX also dropped down a bit. I wish emissions would tell you this kind of thing instead of "you failed, figure it out yourself", when they could easily have told me this since they hook up to the computer.
Your higher NOX is a bit odd, maybe try changing the oil and check the CCV components. I bet it's your cat.
freeskier93 is online now   Reply With Quote
Unread 03-31-2011, 07:10 PM   #6
LaddieHanus
Its a hour drive from Nederland to the emissions station in Broomfield so I am pretty sure it was hot enough. The tstat was replaced with the radiator last year and the temp gauge shows no overheating. Leaning to Seafoam and replacing the Cat.
Aftermarket cats dont seem to have a good reputation. Wonder if I have the original around.
Unread 03-31-2011, 07:11 PM   #7
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
TJ's don't have a PCV. They do have a CCV and it's not a valve...
Knuckelhead is offline   Reply With Quote
Unread 03-31-2011, 07:17 PM   #8
bluefox_gt
I thought pre 99 or 2000 had them, I didnt know I know mine doesnt
Unread 03-31-2011, 08:33 PM   #9
AFD113
have you tried this? http://www.amsoil.com/storefront/api.aspx Have had good results. $ back guarantee too!
AFD113 is offline   Reply With Quote
Unread 03-31-2011, 09:37 PM   #10
freeskier93
"Generation Dead"
lol, why do you go to broomfield? There's a testing facility right here in longmont, 45 minute drive from ned.
Unread 03-31-2011, 09:39 PM   #11
freeskier93
"Generation Dead"
Nope, there just two little plastic elbows coming from the valve cover. One goes to the manifold and the other to the intake tube.
Unread 03-31-2011, 09:41 PM   #12
2005X
or go to the one in Boulder. thats where i went and passed
www.youtube.com/kgries
2005X is offline   Reply With Quote
Unread 03-31-2011, 09:46 PM   #13
freeskier93
"Generation Dead"
Ha, I wasn't sure if their was one in boulder. That makes it a 30 min drive.
Unread 03-31-2011, 10:40 PM   #14
SilverTJMike
Boulder one is just past the airport and the jail, end of the road on the left.
Unread 04-01-2011, 12:41 PM   #15
LaddieHanus
I work over in Broomfield so its the closest. I actually live off of Magnolia road so its quicker to take Coal Creek Canyon. Lived in Longmont until about 15 years ago (bought the YJ over at Herbert Motors new in 89) so I have used all 3 stations since Envirotest came in the 90's. Will probably go to Boulder for the retest as Broomfield guys moved me to a different lane yesterday and the 2 cars behind me left before I did. I also try to avold driving in Boulder whenever possible.
Anyone know of anyplace local that has the Seafoam spray. I have a couple of bottles that I bought at NAPA but have not found the spray at Napa or autozone.
