factory fog light wiring - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > factory fog light wiring
Black Friday Sale - Deep Discounts from ExtremeTerrain.com6th Annual, Beat Your Wife to the Credit Card Sale!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-04-2014, 04:47 PM   #1
CLHenderson
I have a 2005 TJ and have a problem with the fog lights intermittently working. The light switch is located in the turn signal lever. I've noticed when I use my fog lights for an extended period of time, the next day they won't work. I also noticed the fog light indicator on the instrument cluster is not light when the problem occurs. Usually by the next day or two everything works fine.
I replaced the factory fog lights with led fog lights and still have the same problem.
If it comes down to the problem being the switch I would rather replace it by using a fog light switch mounted on the dash that looks OEM but I would still like the fog light symbol on the instrument cluster to work.
CLHenderson is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 10:27 PM   #2
geroux
Could be the multifunction switch. I've read about a lot of problems with them. Don't get the OEM one but go to Autozone and get an aftermarket one. I think it's Durolast or something. If you want to use a different switch and still have the indicator it will require figuring what circuit going to the EMIC triggers that and what it needs to do so.
geroux is offline   Reply With Quote Quick reply to this message
