Extreme Novice Regear Thread - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Extreme Novice Regear Thread
Rough Country Jeep Suspension Deals at Rockridge 4WD!Amsteel Blue Synthetic Winch line Free ShippingWarn and Smittybilt Free Shipping Offer
Unread 02-09-2010, 01:24 PM   #76
dualtjs
2011 JK Wrangler
I'm not sure that I'd assume "little to no mechanical skills". Just because he doesn't know all of the component names, doesn't mean he has no skills. My neighbor is an aircraft mechanic for Delta. He doesn't do much of his own car repair, beyond maintenance (works too many hours & wants to spend his free time with his family), but I'd bet that he could handle a regear, if he had a decent manual/write up to use as a reference.
dualtjs is offline   Reply With Quote
Unread 02-09-2010, 01:57 PM   #77
MO2500
Fabramicator
MO2500's Avatar
Your right, I don't know what his background may be. I don't underestimate the OP's abilities as a mechanic either. I just assumed he was an "Extreme novice" as the title of his thread suggests.
I think it's great he's doing this himself
edited previous post to clarify
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 02-09-2010, 06:59 PM   #78
green89yj
Can't wait to see how this ends up for you. I may be in for the same thing pretty soon as I prefer to go faster than 65 on the highway sometimes.
Build
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline   Reply With Quote
Unread 02-09-2010, 08:02 PM   #79
Jay12
youre an inspiration to everyone here man. good luck with the rest of the install
Jay12 is offline   Reply With Quote
Unread 02-09-2010, 08:21 PM   #80
brjeep
Summary
I didn't have time to do any real work on the jeep tonight. But, for my own benefit, I thought I'd summarize my remove-front-axle procedure.
1) chock back wheels, place jeep on jack stands, remove front wheels and place under shovel
2) unbolt diff cover, let fluid drain, later on remove diff cover.
3) Remove the shocks - 2 bolts on bottom tabs and nuts on top.
4) Remove brake calipers - 2 bolts in back. pry calipers off rotor and zip-tie out of the way.
5) Remove rotors (may require persuasion with BFH)
6) Disconnect from stabilizer bar (easy with quick disconnects)
7) Remove straps connecting drive shaft to yoke
8) Unbolt track bar at the axle
9) Disonnect drag link and tie rod at the axle. Requires a "pusher" tool (tie rod removal tool, whatever it's called).
10) Unbolt steering stabilizer and pry out of it's mount.
11) Disconnect drag link at Pittman's arm (need "pusher" tool). This should completely remove the draglink/tierod/stabilizer gizmo.
12) Unbolt upper control arms - bolts are a bit tricky to pull out
13) Unbolt lower control arms
14) Remove springs
15) Disconnect differential vent line
16) Pry drive shaft away from yoke (but remember to catch it when it falls).
17) Find friend to help tote axle over to jack stands.
Play Band of Heathens too loud, sing along 'til realizing the neighbors can probably hear. Switch to Chris Knight, drink Shiner Blonde quietly, wonder if you'll ever get it back in.
(insert your favorite band/beer)
BRJeep, Texas
'04 X, I6 M5 , SuperD35/30 4.11 (Aussie in front, OX in back), 2" BB, 31's
brjeep is offline   Reply With Quote
Unread 02-09-2010, 08:30 PM   #81
flatlander757
I've got the tools and stuff on the way to regear an axle for another JF member this weekend.
I'll try to remember to bring the camera and document the process. You'll also get a look at my sweet notebook which has a decent of random info on different u-joints and part numbers and specs for axles and crap.
When regearing have lots of paper so you can KNOW the specs of each setup attempt and what the result was as far as backlash/pinion depth/pinon preload/gear tooth pattern go.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote
Unread 02-09-2010, 08:33 PM   #82
brjeep
Flatlander757,
Looking forward to it!
BRJeep, Texas
Unread 02-09-2010, 08:34 PM   #83
LuckRider
LuckRider's Avatar
I can't wait to see that write-up.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote
Unread 02-09-2010, 08:40 PM   #84
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
This makes me wish I had another DD so I could tear apart my Jeep and not have to worry about putting it back together by morning, in order to drive to work
Still writhing with anticipation!
-Dave
Shameless plug: www.davidisabeersnob.com
My CJ7 Build Thread
AustinCJer is offline   Reply With Quote
Unread 02-09-2010, 08:58 PM   #85
2GPS4ME
2GPS4ME's Avatar
Joined the plethora of subscribers.
Baby steps to Wednesday night!
2GPS4ME is offline   Reply With Quote
Unread 02-09-2010, 11:27 PM   #86
asknight
brjeep, you're just now far enough along in the process to develop cold feet, night sweats, and impotence......... errr, I mean, far enough along to trot the axles right down to the 4wd shop to have them install and set your gears...
Don't back out now! We're all counting on you!
asknight is offline   Reply With Quote
Unread 02-10-2010, 12:36 AM   #87
remery829
good luck and great idea bud. hopefully this turns out and can become stickied
Ryan
[CENTER][B]vvvthis is what they don't tell you about LCGvvv[/B][/CENTER]
[QUOTE=]...I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...[/QUOTE]
[CENTER][B][U][COLOR="yellow"]SUPPORT OUR TROOPS[/COLOR][/U][/B][/CENTER]
[URL="http://www.cityprofile.com/forum/login.php?do=logout&logouthash=1283292679-9a7df2f9eebd07dc48f628e4fb5cbc1881910fd4"]City Profile[/URL]
remery829 is offline   Reply With Quote
Unread 02-10-2010, 03:29 AM   #88
TJamz
I was just going to say the same.
TJamz is offline   Reply With Quote
Unread 02-10-2010, 05:27 AM   #89
AlexGeorgakis
AlexGeorgakis's Avatar
Yeah baby! This is what JF is all about!!! Keep it up!!!
My HEMI build thread
AlexGeorgakis is offline   Reply With Quote
Unread 02-10-2010, 06:27 AM   #90
epeck87
a shop by me wanted about $2000 to do my axles. im guessing that includes parts but that was still too much for me. i dont know if its worth it for me to get a shop to do it that will back up their work or if i should attempt screwing my axles up lol. you are brave and i respect your motivation to go at this on your own.
Associates Degree in automotive technology
Toyota Expert Chassis Technician
ASE:
A1(engine repair)
A3(manual drive train and axles)
A4(suspension and steering)
A5(brakes)
A6(electrical/electronic systems)
OIIIIO
epeck87 is offline   Reply With Quote
