external light Bar not working - JeepForum.com
post #1 of 8 Old 03-09-2011, 12:11 PM Thread Starter
jfisch
I was replacing a broken light on my external light bar that runs over the windshield yesterday and after splicing and reconnencting the new light then rewrapping the wiring in eletrical tape, i turned on the lights and they all lit up for about 5 seconds then all four of the lights went out and now I can't get any of them to work. The rest of the cars electronics appear to be fine. Any hint as to what I did wrong?
i have little electrical experience. the original wires were gold and the new lights were silver if that matters. btw they are Hella Comet 500's
jfisch is offline
post #2 of 8 Old 03-09-2011, 12:13 PM
srlbotanical
My guess would be a fuse. Are they being run through a relay?
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #3 of 8 Old 03-09-2011, 12:18 PM Thread Starter
jfisch
not sure what that means, but it just occured to me that i have both wires taped together and therefore probably touching eachothers wires. could that be the problem?
jfisch is offline
post #4 of 8 Old 03-09-2011, 12:22 PM
LilyBayXJ
Not as long as the coating is intact. I would definetly check the fuse, and if it's blown, get a heavier duty one. That's what it sounds like to me.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #5 of 8 Old 03-09-2011, 12:25 PM Thread Starter
jfisch
They were dealer installed originally. Where would I find the fuse? (behind the glovebox?) and how can I tell if it's broken?
jfisch is offline
post #6 of 8 Old 03-09-2011, 12:41 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
How did you reconnect the wires?Did you use proper connectors or just wrap the twisted wires with electrical tape?Sounds to me like you accidentally touch a ground with the hot wire.
GOLENJEEPTJ is offline
post #7 of 8 Old 03-09-2011, 12:58 PM Thread Starter
jfisch
Well I matched the colors of the wires, but yeah, all I did was twist the ends of the wires together then taped them.
jfisch is offline
post #8 of 8 Old 03-09-2011, 01:10 PM
timberwolf0122
Step one, go out and get a proper connector, either crimp or a screwdown affair.
Step two, fuse. Take the total wattage and divide by 12 to get the min-amps then get a fuse that'll handle it. EI 4x100W 400/12=33A So you'll want atleast a 35->40A fuse.
Step 3........
Step 4 Profit!
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
electrical issue , hella , light bar , lights , wiring for lights
4wd light not working 97tjeff TJ Wrangler Technical Forum 8 01-06-2010 03:14 PM
4WD Light not working jeepnmike TJ Wrangler Technical Forum 12 07-02-2007 08:48 AM
O/D Light Not Working & Check Engine Light On JeepMom2 TJ Wrangler Technical Forum 2 12-24-2006 09:43 AM
4WD light not working BlueDevil YJ Wrangler Technical Forum 8 12-08-2006 04:03 AM
4wd light not working jeep n00b YJ Wrangler Technical Forum 18 10-13-2006 07:31 PM
