Extending My Bump Stops - JeepForum.com
post #1 of 11 Old 07-26-2010, 07:53 PM Thread Starter
442Wrangler
In like Flynn.
442Wrangler's Avatar
Well I didn't think I would have to but after putting in 3 hours worth of body work making my jeep look good again, I decided it's about time. Duh.
Anyways how do you figure out how much extra bumpstop you need? I have a rough country 3.25 in lift and 32 in tires. I was looking at Daystar's extending rubber replacement things but wanted to see what you guys had to say. Any ideas?
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #2 of 11 Old 07-26-2010, 07:58 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
flex your jeep, before you shock bottoms out and/or your tire hits the fender measure it and adjust your bumpstops accordingly.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #3 of 11 Old 07-26-2010, 08:01 PM Thread Starter
442Wrangler
In like Flynn.
i guess im not sure how, is there an easy cheap spacer or something?
2008 JK Rubicon
1959 Willys Wagon
-Steve McQueen
post #4 of 11 Old 07-26-2010, 08:04 PM
jeepinmichguy_
Soar Forever Six
not sure how to what?
ΜΟΛΩΝ ΛΑΒΕ
post #5 of 11 Old 07-26-2010, 08:34 PM
Imped
Imped's Avatar
This isn't hard. Bump stops prevent two things from happening--tire from making contact with the body and shock from bottoming out. Measure both. Write down the least of the numbers. Now measure from the bottom of the bump stop cup (top of the foam piece....remember, it will compress). Subtract the first number from that. That's how much bump stop you need. That's the simple way to figure it out. There can be other smaller factors that will require a bit more or less bump stop. It's a trial and error process if you like to get things down to fractions of an inch.
OlllllllO
IndyORV
Imped is offline
post #6 of 11 Old 07-26-2010, 10:18 PM
mudb8
want it rite or rite now?
mudb8's Avatar
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #7 of 11 Old 07-27-2010, 10:33 AM
frigginjeep
I used a boat roller...the long cylindrical ones without a taper...removed the stock bumpstop rubber, pulled out the bolt, removed the cup, placed the right length for extension above the cup and used a longer bolt, then reinstalled the factory rubber...works great for about $10 including new longer bolts...
When I did mine, I cut it about 1/2" longer than needed, then used the pressure of tightening the bolt to compress it to the size needed...this helps to prevent extra compression of the bump stop on full stuff of the suspension...
frigginjeep is offline
post #8 of 11 Old 07-27-2010, 09:28 PM
mudb8
mudb8's Avatar
that's all good on the rear, using an extension up front between the cup will get tangled up in the spring drooping the suspension... not so bad on Long arms but 10" travel shocks with Short arms, we got problems.
mudb8 is offline
post #9 of 11 Old 07-28-2010, 06:29 AM
frigginjeep
Would love to understand what you are describing here...
With my 04 LJ, I am on aftermarket adjustable short arms with approx. 2.5"-3" of lift (the lift is a pieced together "Frankenstein" lift - with the front setup currently being a ZJ V8 spring and 2" spacer, soon to be replaced with a 3" spring)...as mentioned in my previous post I have extended my bump stops by dropping the cup and placing a boat roller in there...it is dropped approx. 2" and still has the OEM bumper in the cup. My front shocks have approx. 10.5" of total travel with approx. 7" of that being droop.
The lift has been in for over a year and the only issue I have run in to has been the front spring unseating on maximum flex (and I feel it flexes well - ramped a 695 on a 30 degree ramp - wheelbase is 103.5"), I addressed this by installing spring retainer clips on the lower spring seat...the thought process behind that was to keep the spring attached to the lower seat so that it wouldn't shoot out of place when when the axle dropped out and the upper bumpstop 'post' (<--- for lack of a better term) actually keeps the top of the spring in place so that it can follow the 'post' back up to the upper spring seat.
post #10 of 11 Old 07-28-2010, 06:37 AM
gabriel05
To extend my front bump stops I just bolted two hockey pucks to the center of the axle spring bucket. Cheap and easy. Each puck is about 1" worth of extension.
Black Jeep Society Member
gabriel05 is offline
post #11 of 11 Old 07-31-2010, 09:34 PM
Ajamant
I've seen the hockey puck method, and was actually impressed. Cheap and gets the job done. Bump stop extensions for the front don't exactly break the bank at 20$ or so. Wish I woulda put them in before I stuffed my pretty toyo's so far I shaved every other outer lug on my inner fender..... Doh!!!!!!!! Sway bar disconnects with winch and no bumpstop extensions = angry tires.
04 TJ/3" OME/1" MML/1"BBL/3/4" coil spacers up front/discos/Extended bump stops/adj. Rear track bar/hi-lift/ 33x10.5x15 toyo MT on steelies/Epi9000superwinch/nates front bumper/160amp alternator
06KJ CRD with GDE eco tune/samco's/fumoto/tow package/brake controller
Ajamant is offline
bumpstops , bumpstop , extending , extended , tj , wrangler
Bump Stops do I need them? wanabejeeper YJ Wrangler Technical Forum 8 04-05-2010 02:50 PM
Bump stop extenders pushing past Bump stops. KraZeDav YJ Wrangler Technical Forum 5 09-12-2009 03:57 PM
are the bump stops suposed to hit when i go over a bump? MC_NickP TJ Wrangler Technical Forum 10 03-01-2009 06:40 PM
Bump Stops... Pyroteknik701 TJ Wrangler Technical Forum 8 03-08-2007 11:40 PM
bump stops... johnWJ TJ Wrangler Technical Forum 1 09-03-2005 04:50 AM
