Extended front sway bar links - JeepForum.com
post #1 of 6 Old 09-03-2005, 06:36 PM Thread Starter
newbomb
newbomb's Avatar
2014 JK Wrangler
I have a 3" lift and the factory sway bar links on the front end. Are these too short? It seems the sway bar is angling down and has a lot of tension. What is the correct angle for the sway bar? Thanks.
Former Jeeps
2001 Silver TJ
Rusty's 3" lift
33x12.50 BFGs on MT classic II's
Flowmaster 50 Delta Flow
Rusty's Airtube w/ K&N filter
Sirius Satellite Radio
Stebel 139dB Air Horn
1989 Blue YJ w/ TJ Body
2" BL
31x10.50 LTXs
Cab Top
newbomb is offline
post #2 of 6 Old 09-03-2005, 06:41 PM
unrefined
unrefined's Avatar
I "think" its 5 to 10 degrees above level. And optimal is 7 1/2. I could very well be wrong on the numbers but as you look at the sway bar end it should be angled upward front to back. Meaning the end(link attach point) is higher than the sway bar itself.
Air Force Jeep Club Member #10
unrefined is offline
post #3 of 6 Old 09-03-2005, 06:44 PM
TJ on the Rocks
TJ on the Rocks's Avatar
X2 , it is 10 degrees above level .
TJ on the Rocks is offline
post #4 of 6 Old 09-04-2005, 08:59 PM Thread Starter
newbomb
newbomb's Avatar
2014 JK Wrangler
I've looked everywhere and cant find extended links. They are either part of a kit or discos. I'd rather not spend the money for the discos since I dont need them. Has anyone purchased the links for a 3" lift separately?
Former Jeeps
2001 Silver TJ
Rusty's 3" lift
2" BL
31x10.50 LTXs
Cab Top
newbomb is offline
post #5 of 6 Old 09-04-2005, 09:08 PM
btolle
With JKS quick disconnects optimal is 10 degrees for a TJ per the instructions at http://www.jksmfg.com/db/quicker_disconnects/ that is, the rear of the swaybar should be higher than the front by 10 degrees.
I don't know of any links that are longer except quick disconnects. You might try measuring the links on a Grand Cherokee and see if they are longer, if so you could get them from a junkyard.
Bill Tolle
05 Rubicon
04 Liberty
If you love offroading and want the trails to stay open please join Blueribbon Coalition.
"Preserving our natural resources FOR the public instead of FROM the public"
http://sharetrails.org/
btolle is offline
post #6 of 6 Old 09-04-2005, 09:10 PM
trailboss
I put a 2" lift on my 98, and within a month the factory link on the drivers side broke....coincidence? I dunno....
Replaced them with Teraflex quick disco's and no regrets.
2002 Wrangler "X".
An educated, armed populace cannot be enslaved.
trailboss is offline
Rough Country 2.5" spring & 3/4" spacers extended sway bar links? drewtj05 TJ Wrangler Technical Forum 24 11-04-2009 01:18 PM
rear sway bar extended links safarimike TJ Wrangler Technical Forum 2 07-07-2008 11:04 AM
Sway Bar Extended End Links DixiesCJ3B TJ Wrangler Technical Forum 1 02-19-2008 12:55 PM
Rear extended Sway Bar links... CHRRRIS TJ Wrangler Technical Forum 7 04-22-2007 02:40 PM
Front Sway Bar Links iridium TJ Wrangler Technical Forum 7 02-13-2007 11:26 AM
