Quantcast Extended Front Brake Lines Needed? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Extended Front Brake Lines Needed?
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 01-19-2007, 01:03 PM   #1
Want24Wheel
Junior Member
My current lift set-up is:
OME HD Kit + 3/4" Spacers, 1" MML, 1.25" JKS BL. I have been running this set-up for several years without a problem, but I just put on an RE adjustable front track-bar to finally re-center my front axle. Control arms are still stock.
RE claims their adjustable front track-bar will allow more wheel travel than the stock unit. How much I don't know, but I thought I read somewhere up to 30%.
Do I need to be worried about extending my front brake lines now that I should have more articulation? Anyone have experience running a similar set-up?
Thanks
Joe
99 Sport, 2.5" OME + 3/4" spacers, 1.25" JKS BL, 1" MML, D30/Quik-Lock, Super35/Detroit, 2LO, 4.10's, 33" Maxxis Bighorns, lots of skid plates.
Want24Wheel is offline   Reply With Quote
Old 01-19-2007, 01:08 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
You don't mention your lift height but probably not. The easiest way to know for sure is to jack the front of your Jeep up and then support it with 6-ton jackstands under the frame so the front suspension can droop fully. Then you'll know for sure.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 01-19-2007, 01:17 PM   #3
BluesMan
You also need to disco the sway bar and remove the tire, jack up where the brake drum is to see full flex.
Or get a fork lift.
...Don't follow Chili Palmer into the trees...
BluesMan is offline   Reply With Quote
Old 01-19-2007, 01:21 PM   #4
Andy-WhiteTJ
If you think you do need extended lines, the cheapest way is to go to local Autoparts store and get YJ front brake lines. Worked great for me.
1998 White TJ with a whole lotta stuff...
President:Hudson Valley 4 Wheelers, Inc. (a 501(c)(7) Not-for-Profit Corporation)
Member: NOVA (Northeast Off-road Vehicle Alliance)
Andy-WhiteTJ is offline   Reply With Quote
Old 01-19-2007, 02:55 PM   #5
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Using YJ brake lines like Andy-WhiteTJ suggested will give you about 3" more length.
When you check to see if your current brake lines are long enough, don't forget to check with the wheel turned too.
98 TJ
Wheelin98TJ is online now   Reply With Quote
Glock Forum
