Exhuast Issue - JeepForum.com
post #1 of 6 Old 08-23-2010, 10:11 AM Thread Starter
98GP
Exhuast Issue
This is my issue...
I am leaking at my connection point between the manifold and down pipe. It is puffing exhasut pretty good. I dont think my manifold is leaking because I have not heard any exhaust leaks until this leak. So how hard is it to replace the gasket in this connection point? Can the gasket be change with out damage to the manifold and down pipe?
I am dealing with a 12 year old/125K exhaust system. I know this is going to be F.U.N.
98GP is offline
post #2 of 6 Old 08-23-2010, 10:14 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Spray the bolts with some PB Blaster or some type of penetrating oil first.Let it soak! It's an easy task.
GOLENJEEPTJ is offline
post #3 of 6 Old 08-23-2010, 10:30 AM
everydayTJ
Yep, PB Blaster will save you lots of time and sweat. Mine has 190k on it, and it wasn't too bad at all, so hopefully you'll have the same luck
'97 TJ daily driver since 2004
There can be no divided allegiance here. Any man who says he is an American, but something else also, isn't an American at all. We have room for but one flag, the American flag, and this excludes the red flag, which symbolizes all wars against liberty and civilization, just as much as it excludes any foreign flag of a nation to which we are hostile. We have room for but one language here, and that is the English language, ... and we have room for but one soul loyalty, and that is loyalty to the American people.
-President Teddy Roosevelt (1919)
everydayTJ is offline
post #4 of 6 Old 08-23-2010, 11:24 AM Thread Starter
98GP
"PB Blaster..." Yep, call me skeptical...
This will be plan A. I think the hardware is beyond PB and I will be quickly moving toward plan B...cut the bolts.
So changing this gasket is as simple as disconnecting the down pipe from the manifold as long as no damage is done to either?
98GP is offline
post #5 of 6 Old 08-23-2010, 11:38 AM
GOLENJEEPTJ
Correcto mundo!
post #6 of 6 Old 09-07-2010, 07:00 AM Thread Starter
98GP
PB blaster is half good. One of the nuts on one of the bolts at the manifold to front pipe connection worked loose, the other broke. The fornt pipe flange on the side that broke is so diterated that it needs fixed. I am tring to find a way to fix the flange with out replacing the front/down pipe. The front pipe is in good shape. Can I find a replacement flange...Something to clamp to the front pipe then bolt to the manifold flange?
98GP is offline
exhaust , leak
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 06:07 PM
new exhuast set up is on its way itsgroll YJ Wrangler Technical Forum 4 10-06-2008 07:24 PM
Exhuast Garpo YJ Wrangler Technical Forum 3 01-11-2007 05:18 PM
Exhuast 89_Sahara YJ Wrangler Technical Forum 7 10-08-2005 08:01 PM
Exhuast ? 90yjjeep YJ Wrangler Technical Forum 9 01-13-2005 01:16 AM
