#1 | |
Exhaust Leak Question
Ok Guys heres a good one for you. I have a 99 wrangler se as you will see in my signature. Anyway I have a ticking noise (obvious exhaust leak). You can see the leak coming from where the manifold flanges into the exhaust pipe. Now you can tell me its a donught gasket if you want but if you look at a 4cyl jeep and take it apart you will notice that there isn't a gasket at all. However weird and or unbelieveable this may sound it is true. My uncle a service manager at a ford dealership confirmed this. He suggested that I take it to an exhaust shop and have them fix it to to make it easier. My question is could I not just buy a liquid exhaust gasket compund and put it in where the manifold flanges to the pipe? That would stop the leak right? Or should I try and find an impact wrench and tighten it as much as possible and hope that works?
Matt (two4zero) [FONT=Franklin Gothic Medium]99 wrangler SE[/FONT] army green (pretty close anyway) 31" BFG A/T's. 4cyl |
#2 |
4 cyl TJ's often break their outer exhaust manifold studs, are you sure your's isn't broken or completely missing? Up here in the great white north, the warranty was extended to 8 years for just this thing. I had mine replaced under warranty last year.
As for an impact....uhhhh No. For SURE you'll break it then ![]() |
#3 |
I have a 02 SE and had a rattle noise that the dealership traced to the same flange bolts being loose. Tightening the bolts fixed the probelm, but temporarily. A few months later and guess what...the rattle sound is back, but I get it at a lower speed/engine rpm. I plan on letting the dealership handle it again as I'm still under warranty.
Concur with not using an impact wrench in fear of snapping or stripping the bolts.
2002 SE / 4 cyl / Auto / 3.73 Gears Skyjacker 2" BB Skyjacker Hydro Shocks Skyjacker Steering Stabilizer 15x8 Jeep Canyon Wheels 32X11.5X15 Dunlop Mud Rover Spidertrax Wheel Spacers Daystar 1" BL JKS MML ____________________________ 2005 Grand Cherokee Limited 5.7L HEMI |
#4 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
