exhaust leak between header and exhaust piping - JeepForum.com
post #1 of 8 Old 06-06-2009, 09:02 AM Thread Starter
03rubiconMG
So i have an exhaust leak at the connection where the header connects to the rest of the exhaust, i was told that there is no seal in here other than some metal things and mine just moved which is why i have the leak is this true or was i told wrong?
2003 white rubicon on 37s
03rubiconMG is offline
post #2 of 8 Old 06-06-2009, 09:28 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #3 of 8 Old 06-06-2009, 09:41 AM
vtx531
Try tightening the bolts first. I had a leak because the bolts worked loose.
vtx531 is offline
post #4 of 8 Old 06-06-2009, 12:14 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
There shouldn't be any gaskets between exhaust manifold and downpipe.Just 2 bolts above each cat.
GOLENJEEPTJ is offline
post #5 of 8 Old 06-06-2009, 12:31 PM
TheBoogieman
Disturbed
My 98' had the metal ring shown in the diagram.
post #6 of 8 Old 06-06-2009, 12:50 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Your 98 didn't have the 2 piece manifold and Y pipe...
Knuckelhead is offline
post #7 of 8 Old 06-06-2009, 12:51 PM
GOLENJEEPTJ
Well between my 02 and my son's 04 both have gone from stock exhaust manifolds to headers and neither of them come with any type of seals or gaskets.It's a straight up install with just tightening the 4 nuts and bolts.
post #8 of 8 Old 06-11-2009, 08:02 AM Thread Starter
03rubiconMG
I believe i have what the boogieman linked to above. the bolts that are in right now are rusted and a half im just going to cut them all out and then put new ones in and reset the metal ring if i have to.
exhaust leak again. possibly header JSBlu974X4 TJ Wrangler Technical Forum 3 08-11-2008 04:24 PM
exhaust piping jeepsteads TJ Wrangler Technical Forum 1 04-21-2008 04:08 PM
Diameter of stock exhaust piping? 04WranglerX TJ Wrangler Technical Forum 2 07-16-2007 08:55 PM
06 TJ exhaust piping FourbyFour TJ Wrangler Technical Forum 1 02-20-2007 05:43 PM
what size exhaust piping? RescuedJK TJ Wrangler Technical Forum 4 10-21-2004 03:32 PM
