Exhaust leak? - JeepForum.com
post #1 of 10 Old 09-07-2012, 09:55 PM Thread Starter
BlackNBlue97
Exhaust leak?
My 97 TJ 4.0L makes a sputtering sound when climbing a hill at 35-65 MPH. It sounds like exhaust, but the emissions inspection guy said if there was a leak, it wouldn't have passed. Sounds like it is coming from driver side front and "echoing off the pavement." I can't reproduce the sound sitting still and revving. Any ideas?
I've been thinking about a new exhaust to give it a little "throat." Any suggestions for good sounding and efficient exhaust systems. Keep in mind I live in a suburban county which requires annual emissions inspections.
BlackNBlue97 is offline
post #2 of 10 Old 09-08-2012, 06:16 AM
johnxjeep
Check up under there and see if your header is cracked.
Mine was making a similar noise and ended up being a cracked exhaust header.
JMO
johnxjeep is offline
post #3 of 10 Old 09-08-2012, 02:33 PM
xjcountry
Check your exhaust manifold bolts,some tend to break off or even back themselves out especially the very last one,or one closest to firewall. i had a yj that the bolt broke off and a tj that the bolt or stud just coming loose making it sound like an awful exhaust leak.
xjcountry is offline
post #4 of 10 Old 10-03-2012, 11:54 AM
FlyingMonkey
My wifes LJ is doing the same thing and today when I was doing her oil change I hunted it down and 1 of the coupler bolts is missing from the front pipe, connecting pipe to manifold. Been searching online and cant find the bolt size anywhere. Dont want to take 1 of the others out if I dont have to since its kind of a pain to get to them with the cats in the way. Anyone know the bolt size by chance?
FlyingMonkey is offline
post #5 of 10 Old 10-03-2012, 01:28 PM
Maverick906
My sister recently bought a jeep with an exhaust leak. Turned out to be the weld around the O2 sensor behind the cat failed. As for brand of new exhaust, Flowmaster 40 sounds great around town but on the highway at high rpms it sounds a little ricey.
Maverick906 is offline
post #6 of 10 Old 10-03-2012, 04:11 PM
shatteredsoul
Monkey, have a look at part # 03127 on Advanced auto. The bolt should be 3/8"x 1 3/14".
Also the 4.0 exhaust manifolds are notorious for getting cracks around the welds. Mine sounded like a small lifter tick/peck under load and was cracked almost all the way around the collector.
shatteredsoul is offline
post #7 of 10 Old 10-03-2012, 04:14 PM
JBTJ
With the engine running, dribble some ATF down the throttle body, may have to keep the RPM's up a bit. It will smoke like hell but it will show you a leak if you have one.
JBTJ is offline
post #8 of 10 Old 10-04-2012, 10:05 AM
FlyingMonkey
Put a 3/8-16 x 2" bolt with lock washer and flat washer on it today and leak gone. Was hoping it wasnt a cracked manifold, so i was pleased when the leak was gone. Bolt must have just fell out on her sometime.
post #9 of 10 Old 10-04-2012, 02:26 PM
shatteredsoul
I just realized I typo ,the size should have been 3/4" not 3/14", anyway glad you got her fixed.
post #10 of 10 Old 10-04-2012, 03:08 PM
FlyingMonkey
Yeah I figured it a typo lol, thanks.
Top it off she had thrown a code for the O2 sensor and that has went away after the 5th start since fixing exhaust leak.
exhaust
06 TJ Exhaust leak SwiftJeep TJ Wrangler Technical Forum 3 08-22-2012 11:18 AM
exhaust leak where exhaust meets cat psyklone YJ Wrangler Technical Forum 3 05-04-2010 10:43 PM
New jeep owner! (exhaust leak and oil leak) Mindcrime13 TJ Wrangler Technical Forum 9 03-04-2010 01:34 PM
exhaust leak between header and exhaust piping 03rubiconMG TJ Wrangler Technical Forum 7 06-11-2009 08:02 AM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 12:46 PM
