Exhaust issues - JeepForum.com
post #1 of 2 Old 04-04-2010, 01:37 PM Thread Starter
stockstuck
Exhaust issues
So, I just replaced my stock catalytic converter with a magnaflow universal fit cat. At the same time I figured I may as well go ahead and replace the cat-back. I decided to go with the dynomax exhaust. When I tried to install these parts, I realized that both the cat and cat back together would not be the correct length to fit around the axle and would not fit together due to the size of the piping. I cut small pieces of piping to link the pipe coming from the manifold to the cat and then another link from the cat to the muffler. To create a seal I used exhaust u-bolt clamps and filled in gaps with a heat and moisture resistant putty, a certain type of exhaust joint and crack and sealer. Will this hold off-road? Is there another way I can seal the joints? How much might it cost to take it to someone to have them weld the joints? I also think i may need to bend the tailpipe away from my trailer hitch, as it is about a 1/4 to 1/2 inch from it. Anybody done anything similar to this? What did you do? Where might I be able to get this done for cheap?
stockstuck is offline
post #2 of 2 Old 04-04-2010, 03:19 PM
Cesaros
$45 for welding at a good muffler shop. $90 at a Mineke or Midas or any other POS national chain.
You can get liquid welding puddy at autozone or advance. Mix it up, cake it on, and after a day of driving it will harden and seal almost as well as having it welded.
If your exhaust hangers are strong enough, it will hold offroad. I would suggest replacing your stock hangers with much stronger ones.
Cesaros is offline
catalytic converter , dynomax , exhaust , magnaflow , muffler
Exhaust leak. Any related issues? YJake YJ Wrangler Technical Forum 0 08-27-2009 07:44 PM
Exhaust Issues... Thisisaustin Wrangler General Discussion 8 08-24-2009 06:12 PM
11mpg, cooling and exhaust issues. UltimatE YJ Wrangler Technical Forum 5 09-21-2008 07:10 PM
Help a new owner- exhaust issues 87rangler YJ Wrangler Technical Forum 5 05-02-2007 09:40 PM
Exhaust issues bulltrout YJ Wrangler Technical Forum 1 02-28-2007 12:11 PM
