Exhaust hitting passenger side upper control arm mount - Page 2 - JeepForum.com
post #16 of 17 Old 08-02-2010, 04:00 PM Thread Starter
05RedRME
Thanks Blaine, just got back from the muffler shop and your idea did the trick. And you really can't tell its been modified unless you know to look for it. Thanks again sir.
05RedRME is offline
post #17 of 17 Old 03-29-2013, 05:26 PM
Necko2529
Necko2529's Avatar
Hello. I decided to bump this old thread instead of starting a new one.
I installed rokmen tt and had the same problem the OP had and decided to mod the 3rd cat hanger/trans mount (NV3550) to stop the rattling.
Now here's the problem. First thing i did was support/slightly lift the trans and then took some measurements and ended up cutting out an inch out of the mount/bracket. After welding it back together i had to force the mount with the exhaust hooked to it to slide underneath the trans mount to get it to bolt back up. After putting the skid plate back on i realized i screwed up the measurements and now mu muffler is riding on the back lip of the skid. I also worry about the tension i created on the exhaust after forcefully pulling it down to bolt the hanger to the transmission...
What are my options here? I would hate to cut the bracket once again to make it longer, afraid of that many welds eventually cracking and breaking...
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
exhaust , tj
98 rear upper passenger shock mount PurpleTJ TJ Wrangler Technical Forum 3 12-28-2009 09:51 AM
Driver side upper control arm kevinofcamelot TJ Wrangler Technical Forum 2 08-30-2005 11:28 PM
bent passenger side upper door half trw YJ Wrangler Technical Forum 4 08-22-2005 09:20 PM
Passenger side Mirror mount Panteradon YJ Wrangler Technical Forum 1 07-29-2005 03:21 PM
Passenger side Upper Control Arm is FUBAR! Sparty TJ Wrangler Technical Forum 9 07-15-2005 08:26 PM
