Exhaust hitting passenger side upper control arm mount - JeepForum.com
post #1 of 17 Old 07-23-2010, 04:29 PM Thread Starter
05RedRME
So I just installed my JKS BL and Brown Dog MML and my UCF Extra clearance tummy tuck, and my issue is my exhaust is hitting on the passenger side upper control arm mount. I have already modified the exhaust hanger to keep the muffler off the skid but now its hitting on the mount and rattles like crazy. What is the easiest way of fixing this problem? Can I dent the exhaust easily or do I have to take it to muffler shop? Any help would be appreciated. Thanks!
05RedRME is offline
post #2 of 17 Old 07-23-2010, 04:44 PM
Imped
Imped's Avatar
Ditch the stock muffler
OlllllllO
IndyORV
Imped is offline
post #3 of 17 Old 07-23-2010, 04:53 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You have two passenger side upper control arm mounts on the frame. One is located in the front of the rig and the other is in the rear of the rig. The "exhaust" consists of at least three different parts, two of which commonly contact the mounts, front and rear if you relocate the belly skid.
Which end of the vehicle are we working on here?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 17 Old 07-23-2010, 04:56 PM Thread Starter
05RedRME
Ha, My bad Blaine, it is hitting on the front upper control arm mount.
05RedRME is offline
post #5 of 17 Old 07-23-2010, 04:59 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Take it to the exhaust shop and have them cut a small section out of the tube(s) that wrap around the front of the oil pan and weld it back together. Not too much or you might cook the starter.
I am Savvy
mrblaine is offline
post #6 of 17 Old 07-23-2010, 05:13 PM Thread Starter
05RedRME
OK, thanks Blaine.
05RedRME is offline
post #7 of 17 Old 07-26-2010, 08:21 AM
-dirt-
Did you make sure the manifold bolts were tight?
When I installed the 2" "original" UCF skid, the exhaust hit the front PS CA mount. Turns out it was sagging a bit from loose bolts. I also had the exhaust hanger lengthened that is welded to the cat.
-dirt- is offline
post #8 of 17 Old 07-31-2010, 09:06 PM Thread Starter
05RedRME
I've read numerous people use a BFH, a pry bar and a block of wood to dent the pipe to clear the bracket. My question is how are people doing this? Where are you wedging the pry bar and wood?
05RedRME is offline
post #9 of 17 Old 07-31-2010, 09:12 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Cut 3/4" out of the transmission mount, weld it back together and relocate the cat hanger 1" lower, works for me...
Knuckelhead is offline
post #10 of 17 Old 07-31-2010, 09:23 PM Thread Starter
05RedRME
I've already modified the hanger and have the muffler and cat where they can be with clearance all around them. So I can't modified it anymore other wise the muffler will hit on the skid and the cat will be pressed against the tub. Just trying to figure out how people clearance the pipe the 3 tools listed above.
05RedRME is offline
post #11 of 17 Old 07-31-2010, 09:35 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Why don't you just do what I told you to and be done with it?
I am Savvy
mrblaine is offline
post #12 of 17 Old 07-31-2010, 09:39 PM
Knuckelhead
AFSOC Retired
Did you modify the transmission mount? That will allow for less tilt/swing of the exhaust pipe near the RH side of the engine...
post #13 of 17 Old 07-31-2010, 09:40 PM Thread Starter
05RedRME
I was trying to do the cheap route but I will more then likely do it your way Blaine.
05RedRME is offline
post #14 of 17 Old 08-01-2010, 09:25 PM Thread Starter
05RedRME
Hey, Blaine how much do you usually have to cut out of the pipe? Or is just cut little by little til it works?
05RedRME is offline
post #15 of 17 Old 08-01-2010, 09:48 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
View the pipe and the control arm mount from the front. Kinda visualize how much it would have to move towards the engine to clear and take a bit more than that amount out of the crossover around the front of the oilpan where it's the straightest. When you get done if you do it right, you won't even be able to tell the exhaust has been modified.
I am Savvy
mrblaine is offline
exhaust , tj
98 rear upper passenger shock mount PurpleTJ TJ Wrangler Technical Forum 3 12-28-2009 09:51 AM
Driver side upper control arm kevinofcamelot TJ Wrangler Technical Forum 2 08-30-2005 11:28 PM
bent passenger side upper door half trw YJ Wrangler Technical Forum 4 08-22-2005 09:20 PM
Passenger side Mirror mount Panteradon YJ Wrangler Technical Forum 1 07-29-2005 03:21 PM
Passenger side Upper Control Arm is FUBAR! Sparty TJ Wrangler Technical Forum 9 07-15-2005 08:26 PM
