exhaust hits front driveshaft - JeepForum.com
post #1 of 10 Old 12-28-2010, 09:58 AM Thread Starter
greene69
Hey everyone. I bought a 2001 wrangler 4.0 about a month ago. It had a 3-4" lift on it already. The exhaust hits the front driveshaft universal when you take off, but no other time even when off road. I changed both motor mounts, but no change. Possible something was left out when the lift was installed? Exhaust is stock. Don't know brand but has a superlift decal (not much help i know).. Any ideas?
greene69 is offline
post #2 of 10 Old 12-28-2010, 11:51 AM
ohtenwillys
Did the previous owner jump it? haha
ohtenwillys is offline
post #3 of 10 Old 12-28-2010, 12:54 PM
wushaw
Rockin jeep
wushaw's Avatar
You will have to do a little exhaust work in order to make clearance. If you can't do it then take it to a muffler shop.
wushaw is offline
post #4 of 10 Old 12-28-2010, 12:59 PM
cbmadcow
cbmadcow's Avatar
Same problem occurred with my TJ with only a 2 inch lift.
After replacing the headers and exhaust problem went away.
My YJ also starting doing the same thing come to find out where the Exhaust header connects to the down pipe, the coupler was loose. I ended up repositioning the exhaust and re tightening the the couple problem solved.
Kevin
1993 Jeep Wrangler lifted YJ
Previous Jeep 1998 TJ
cbmadcow is offline
post #5 of 10 Old 12-28-2010, 02:03 PM Thread Starter
greene69
Previous owner was a wuss, no off roading, or jumping, this jeep is in for a rude awakening! Thanks guys, heading to Muffler Masters tomorrow!
greene69 is offline
post #6 of 10 Old 12-28-2010, 03:17 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Do you have an adjustable front track bar?...
Knuckelhead is offline
post #7 of 10 Old 12-28-2010, 03:26 PM
BlueFlame
BlueFlame's Avatar
Very simple fix. Adjust the exhaust pipe a little.
Adjusting tool:
For the exhaust pipe, not so much for the driveshaft.
BlueFlame is offline
post #8 of 10 Old 12-28-2010, 05:51 PM Thread Starter
greene69
No, track bar is solid, would getting an adjustable one be an option, seems to have alot of wobble when taking off to.
greene69 is offline
post #9 of 10 Old 12-28-2010, 06:19 PM
Knuckelhead
AFSOC Retired
It's possible...
post #10 of 10 Old 12-28-2010, 08:58 PM
wushaw
Rockin jeep
wushaw's Avatar
Check to see if your differential is centered under the Jeep, carpenters square from a fixed point on each side of the diff to a spot on the frame.
wushaw is offline
exhaust
MBAM hits Matt Gertsch JeepForum Announcements 5 07-09-2010 04:08 PM
