Exhaust clearance concern with UCF skid plate, Brown Dog MML, and JKS BL - JeepForum.com
post #1 of 7 Old 07-07-2010, 11:55 PM Thread Starter
05RedRME
I'm installing a JKS Body lift and Brown dog motor mount lift, in preparation of installing my UCF tummy tuck. I'm installing the original extra clearance skid, not the high clearance one. My question is, will I have any clearance issues with the exhaust hitting my upper control arm on the front passenger side? Also will I encounter any other clearance issues? Any input and suggestions on how to fix clearance issues would be greatly appreciated. Thanks
05RedRME is offline
post #2 of 7 Old 07-08-2010, 09:29 AM Thread Starter
05RedRME
Anyone?
05RedRME is offline
post #3 of 7 Old 07-08-2010, 09:43 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i have a JeepMedic tummy tuck, 1.25" JKS BL, 1" MML, and I had some rubbing of the exhaust on the UCA mount. Little bit of pry bar bending, a little 2x4 with a BFH, banging and bending here and there, and whala, its fine. takes 15 minutes and a ride to double check. start prying at the drivers side first...it will pull it over.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 7 Old 07-08-2010, 10:18 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by 05RedRME View Post
Anyone?
I've done many many raised belly skids even before we built ours. Sometimes the exhaust hits, sometimes it don't and it follows no rhyme or reason I could ever discern.
I've had them rub on the control arm mount so badly that I've had to section an inch or so out of the part around the front of the oil pan. Others don't even get close.
The motor is adjustable side to side, push it all the way to the driver's side when you do the mounts. After you redo the hangers in the back to lift the muffler up, check it and see what needs to be done and go from there.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 7 Old 07-08-2010, 01:40 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I lowered the exhaust hanger by the cat and relocated the other 2 hangers to fix that...
Knuckelhead is offline
post #6 of 7 Old 07-09-2010, 12:55 AM Thread Starter
05RedRME
Did anyone who installed the UCF skid on a Jeep with the 42RLE trans have any fitment issues? Such as bolt holes not aligning or any other problems?
05RedRME is offline
post #7 of 7 Old 07-09-2010, 01:14 AM
Fropleyqk
Fropleyqk's Avatar
Theres about 5 or 6 threads dedicated to UFC installs. Just search for them.
Fropleyqk is offline
exhaust , clearance , ucf , skid , plate
Stock skid plate clearance issues? snsedwards TJ Wrangler Technical Forum 4 02-21-2008 02:10 PM
stupid question about high clearance skid plate jcbr6 TJ Wrangler Technical Forum 7 03-14-2007 09:48 AM
Skyjacker high clearance skid plate... SpeedJeep TJ Wrangler Technical Forum 1 10-23-2004 04:57 PM
Hi-clearance skid plate Roughneck TJ Wrangler Technical Forum 4 05-17-2003 10:27 AM
High clearance skid plate Bachman TJ Wrangler Technical Forum 1 05-16-2003 07:39 PM
