Ever happened to anyone? - JeepForum.com
post #1 of 30 Old 06-05-2008, 12:03 AM Thread Starter
Grey01
Bad news..the jeep which is my dd is currently out of service. I was parking on the side of the road today and as i started to pull forward from a stop, the car lurched forward about 3 feet (similar to how it lurches if you kill it), popped into neutral, and the clutch went to the floor.
The jeep kept running but after i pulled the clutch back out, it became very hard to push all the way down, and now i cant even get it into any gear. After i turned it off and got it pushed into a better spot, my brother and i tried to start it up again to see what was up. now the car has a hard time turning over to start and also does not sound how it should. It sounds like the whole engine is just binding up when i try to start it and it sounds awful.
Now im assuming i need a new clutch, but whats up with it not starting and turning over so hard? Has this ever happened to anyone? I didnt notice any difference in the way the jeep ran or drove before this happened, it seemed very random
Oh and i think its in my info but its a 2001, I6, 5 spd
any help would be greatly appreciated..thanks
Grey01 is offline
post #2 of 30 Old 06-05-2008, 12:17 AM
cpleasant
cpleasant's Avatar
Why did I read this?!?!? I swear, every time I read about something wrong with someone else's Jeep mine catches it (blower resistor, broken D35, broken passenger seat cable, ect) Now you just killed my Jeep, thanks.
Just kidding, I cant help but here is a free bump for you.
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
post #3 of 30 Old 06-05-2008, 01:27 AM
bigchevyman24
bigchevyman24's Avatar
Sounds like the throwout bearing...might as well replace the clutch while you're in there. The throwout bearing should come with a clutch kit...around $175 plus installation
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #4 of 30 Old 06-05-2008, 03:49 AM
dodgetk81
I would guess its the clutch master or slave. Check the fluid and see if the master is empty. If it is it something blew out and you need a new one. You dont need to remove the trans to change.
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
post #5 of 30 Old 06-05-2008, 10:39 AM Thread Starter
Grey01
Thanks for the responses, but would those cause the car to not start while in nuetral?
I also discovered that the breaks are really hard to press now, and theres no power steering when the key is in the on position
Grey01 is offline
post #6 of 30 Old 06-05-2008, 10:45 AM
HipCheck_1
Power Steering does not work well if the engine is not running.
05 Jeep Wrangler 2.4l 4 cylinder
3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT
Low Ouput 4-cyl Jeep club member #151
HipCheck_1 is offline
post #7 of 30 Old 06-05-2008, 10:49 AM Thread Starter
Grey01
thats what i suspected, but wasn't positive..
Grey01 is offline
post #8 of 30 Old 06-05-2008, 10:53 AM
06rubicon
2017 JK Wrangler
You may have some clutch parts wedged between the flywheel and the bellhousing causing the engine to bind.
06rubicon is offline
post #9 of 30 Old 06-05-2008, 10:55 AM
jeepman44
This situation does sound like the throwout out bearing. If i were you i would replace the whole clutch if you are going to be in that area of the car
97 TJ sharah Black Bf goodrich all terrains 31"
jeepman44 is offline
post #10 of 30 Old 06-05-2008, 10:57 AM
walldk
Good Advice
Step away from from the vehicle and seek professional help.
walldk is offline
post #11 of 30 Old 06-05-2008, 10:58 AM
jeep_freek
wishin' I was wheelin'..
jeep_freek's Avatar
what a dipstick you are for saying that..! That's like saying the alternator doesn't charge when the engine is stopped. Try and be part of the solution, not the problem.
Now back to the question..
sounds like the clutch took a dump for sure.. and why the engine wouldn't restart..? How's your battery.. and the cables..?
-Bruce
'99 TJ Sport, ragtop, RE 4 1/2 lift, Magnum 318 V8, Atlas II, 4.88's, Dana60's, 35" BFG MT's, Detroit\ARB, 9500lb DualForce powerplant winch
White Jeep Club Member #630
o_o_o_o
/| ,[_____],
|ŻŻŻL--O||||O-
()_)Ż()_) ŻŻŻ )_)
jeep_freek is offline
post #12 of 30 Old 06-05-2008, 11:08 AM Thread Starter
Grey01
-Bruce
We tried charging the battery right away..had some jumpers on it for a while, and it still does the same thing..
the engine turns over but just sounds terrible while doing so, and it doesn't ever start up
We pulled it back down to the dealer this morning..pushed it up onto a car trailer and pulled it with my buddy's ram. The dealer i got it from is in a city just south of my about 15 miles away, and the best price i could get on a tow was about $120..i was not doing that. I've had the jeep for about 2 months now, so i'm hoping that the dealer will try to back their name a little bit and cut my some sort of deal
Me and my bro decided to just try the dealer instead of doing things ourselves. He's a diesel mechanic and he knows his way around..but its just that..hes a diesel mechanic, and he tries to stay away from cars. Also if the dealer wont do anything for my, i know a guy thats about 3 buildings down the road that has a garage, so he'll help me out
Grey01 is offline
post #13 of 30 Old 06-05-2008, 11:48 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your clutch uses an external slave cylinder that is held to the bell housing by two bolts. Remove those two bolts then pull the slave cylinder which has a plunger protruding out of it away from the bell housing. Don't let the plunger fall out of the slave cylinder housing and into the bell housing, that will ruin your whole day though it's not prone to do so. That plunger is what moves/controls the clutch mechanism. Then watch/feel the plunger as someone moves the clutch pedal up and down. Does the plunger move in and out as the clutch pedal is moved up and down? Does the plunger move out forcefully as the clutch pedal is depressed? If so, then the problem is clutch related and you'll have to pull the transmission to see what's happening. If not, you just have a hydraulic clutch linkage problem that is very easily fixed.
If it's clutch related, you can go to www.dialaclutch.com/ and buy a complete Luk clutch kit (avoid the Centerforce clutches, they're overpriced and don't have any benefits for a Jeep) for around $130 or so. Their kit will include a new clutch disk, pressure plate, throwout bearing, pilot bearing, and clutch alignment shaft. Good luck with it.
Jerry Bransford is offline
post #14 of 30 Old 06-05-2008, 11:51 AM
HipCheck_1
-Bruce
The OP was trying to equate a lack of power steering to the rest of his problems so I kindly took that out of the equation for him. Everyone already pointed to the throw out bearing/clutch. It also looks like it helped him based on his reply to me...
So who is the dipstick now?
post #15 of 30 Old 06-05-2008, 12:24 PM
metal123123
Sounds like the master, or slave in regards to the clutch issue. A simillar deal happened to me when i had my xj and when I had a look at it the slave had a leak. I pulled the tranny replaced the slave and all was well. hope that helps
metal123123 is offline
Has this happened to you? richupnorth TJ Wrangler Technical Forum 2 02-28-2009 12:04 AM
what happened KC1337 TJ Wrangler Technical Forum 0 01-28-2009 12:23 AM
What Happened?? vertresq YJ Wrangler Technical Forum 2 05-22-2006 10:57 AM
What happened? HVACman TJ Wrangler Technical Forum 3 05-09-2006 06:33 PM
What Happened? BudmanV6 YJ Wrangler Technical Forum 15 01-27-2005 11:40 PM
