Evap Canister Relocation OPTIONS for a 2006 TJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Evap Canister Relocation OPTIONS for a 2006 TJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 04-29-2015, 02:21 PM   #1
bordeauxman
Yellow-Rubinator
bordeauxman's Avatar
I have a 2006 TJ that has been stretched about 5" along with new D60 axles & 37" Pitbull Rockers and coilover springs the rear. Genright Crawler gastank & skid enabled the stretch.
I do not have enough room for the EVAP canister in its stock location in the back right wheel well. The rig is registered in NY and the lack of evap canister throws codes and the check engine light which doesn't work so well during the inspection process.
Yes, I've read around 20 threads (mostly older ones) discussing the evap canister and pictures are missing from many of them.
I'm looking for pictures and recommended places for the evap canister to be relocated.
With the 2003 and later technology, I read that the canister should not be more than 3 feet from the gas tank so with my rig, that probably means inside the back hatch or under the rig. Obviously, I would want a skid plate under it.
Does anybody have any recommendations, especially with pictures?
Thank you in advance.
2006 Rubicon, Detonator Yellow, 5.5" Clayton Long Arm lift, 37" Pitbull Rockers, Atlas 4:1 transfer case. Dyntrac PR60 axles (RCV shafts in front), ARB F&R Lockers, Superwinch Talon 9.5 Winch, Metal Cloak Fenders, Currie Antirock in the front, Clayton TJ skid, Genright Crawler gas tank & skid. Fox Coilover shocks in the rear. 5" WB stretch.
bordeauxman is offline   Reply With Quote Quick reply to this message
Unread 04-30-2015, 12:44 AM   #2
mudb8
want it rite or rite now?
mudb8's Avatar
The canister can go anywhere there's room like the floor pan or deleted. I leave the rest of it in place and cut down the bracket.
On the lj it can move rearward to the tj location.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
